Pre-Installation Floor Prep
Posted by kimberlyrkb (My Page) on
Fri, Jun 22, 12 at 17:00
Hi All,
We want to replace the floor in our basement TV room. The floor is a concrete slab on dirt that currently has carpet and pad on it. The house has always felt/smelled musty even though we've not seen water coming in, and we think this carpet is part of the problem. I also think that the slab itself may be an issue.
We're looking at a vinyl plank flooring product, probably Karndean loose lay tile. Would it make sense to apply something like Drylok masonry waterproofer or Drylok floor paint before we install our flooring, regardless of what we get?
RE: Pre-Installation Floor Prep
If you are concerned about a possible foundation leak. I would suggest you get an inspector out first to get their opinion. While its no necessary since havent seen water. Now would be the time since you are rippin up the carpet. And after what the inspector then proceed.
Thanks for a fast answer Greg! We're not really concerned about a foundation leak, but I guess we'll never know what we'll find when we rip up the carpet. Good point. Thanks.
Once you have it down to bare slab, tape down a piece of 2x2' clear plastic on the floor and leave it for 48 hours. Any moisture coming up from beneath will show up under the plastic.
