AO catarina - grout joint size?
Posted by cottonpenny (My Page) on
Mon, May 14, 12 at 20:33
Using AO Catarina coliseum white in the master bathroom.
Tile store says they will do a "tight grout joint" for an extra $265. Still waiting on what exact dimensions each option is.
What size grout joint did you use? AO recommends 1/8" for floor, 1/16" for walls.
RE: AO catarina - grout joint size?
Follow the manufacturer's directions if you want any type of warranty. Believe me, even if the spacing doesn't cause a claim, they will use that as a "not installed per instructions" excuse not to warrant it.
I'm an ex installer of 25+ yrs and I had my own store...they will use any excuse not to warrant anything.
