Hardwood over linoleum
Posted by serendipity01 (My Page) on
Thu, May 26, 11 at 11:00
We would like to put hardwood down in our den, which currently has linoleum (no asbestos). The flooring is in good condition and we're reluctant to try to pull it up because it's so firmly glued down, except for one small area.
Would it be possible to reglue that one place, and then put down a hardwood floor over it? Or do we need to pull up the lino and attach the hardwood to the subfloor. I have a feeling that if we try to pull up the lino, it would be easier to rip the whole thing out and lay a new subfloor. Any suggestions?
Thanks,
claire
RE: Hardwood over linoleum
If this is a nail down over the flooring, just go right over it.
Are you doing this yourself or using a company that is supplying the flooring? If someone else is installing it what do they suggest? You may gain height you don't want by keeping the existing flooring which would be more noticeable by any entrances. Over time you will have a better job if you remove the old floor. I say this from my experience in a kitchen and what happened over 22 years.
We installed (glue down, not nailed) our engineered wood flooring over the old linoleum in August 2009. The linoleum was not in the entire room (see pic below) and it was adhered to the concrete sub floor very firmly. There were only a few places along the edges (where the linoleum met the carpet) that were not adhered very well. Dh cut away those small areas of linoleum. I bought a special linoleum floor stripper product at Ace Hardware that I used to prep the surface of the linoleum before installing the wood. Dh also used a product (I forget the name of it right now) to smooth out the transition on the area where the linoleum stopped and the bare concrete began. He feathered it out to flatten out that transition. He used that same product to flatten out other areas where there were low spots on the concrete. We used a very good glue product called Bostik's Best to glue down the wood. So far, we've had no problems.
Before, you can see where this room had linoleum come out from the kitchen area and into about 1/3 of the family room.
