| We are using Black Walnut boards from our property for flooring in our son's new house. (dining and living room areas) My husband has installed the boards. They are beautiful and ready to be sanded. The finishing process is making me nervous. Any tips for a flawless finish? Any preferences in polyurethane? The kids have two dogs. Thank you! |
- Posted by art_teacher_mom (My Page) on Sat, Apr 2, 11 at 22:50
| We have finished and refinished wood floors in previous homes. I am no expert, but I will say we had horrible experience with minwax products. (Wouldn't dry, peeled when it finally did dry.) We had good experience with Verathane and Waterlox and also Deft. A relative of ours told us do NOT sand above 80 grit or the stain will not soak in properly. He also recommended a method called "water popping" where you damp-mop the raw wood with water first to open the grain a bit. You could probably look this up. (He does this for a living in Napa Valley, so I trust him!) My main point was to stay away from Minwax on floors! |
- Posted by lindarenee (My Page) on Sun, Apr 3, 11 at 22:55
| Thank you, I appreciate all advice! I want the kids to have beautiful floors to enjoy for years. We will stay away from minwax and research the water popping. |
| If you can't hire a professional, then you are going to have a steep learning curve to negotiate. Be aware that most floor finishing products available to the average consumer are not a good quality. If at all possible, you want to purchase from a floor materials dealer or an internet vendor after you decide what finishing product you want to use. Lots of ways to finish wood...learn all you can, even if you go with a professional. You will then know what you are paying for. |
- Posted by oldhousegal (My Page) on Mon, Apr 4, 11 at 12:41
| Do you want to go toxic or non-toxic? Check out the different finishes with Polyurethane versus Tung Oil. May change your mind. With the poly on the floors at my other house, my dog tore it up. Next year I'm redoing the floors in this house with Tung Oil. Check out the realmilkpain.com website for more info... |
- Posted by lindarenee (My Page) on Mon, Apr 4, 11 at 22:15
| Thanks everyone. I need to research quickly because they are hurrying to get the house finished. Perhaps the professional finishes will be more durable than the polyurethane available at Lowes or a Paint store. I don't think they will go for Tung Oil. I am going to use the left over walnut in my bedroom and would consider the Tung Oil for myself. Thanks again, I'll start googling and see what I find. |
| My colleagues advise two coats of oil sealer and two coats of a quality two part waterborne polyurethane. Another says waterlox as a sealer and two coats of Poloplaz. And another says simply two coats of Poloplaz. And one more says Glitza seal and lite scent satin. And the last says Pallman Magic Oil for a velvety and satiny look. See how many option there are for finishing a floor? I'd specify what I happen to find works for me most of the time...i.e. Bona DriFast Natural Stain and then two coats of Bona Traffic Satin after the stain is absolutely dry. Your head is going to swim on this one. Good luck. |
- Posted by lindarenee (My Page) on Wed, Apr 6, 11 at 0:34
| This does get confusing! I'm the researcher and my husband just likes to "get 'er done". I value the experience of others and I'm hoping our experience is not a bad one. The right finish, dust issues, sanding, application technique, fumes - there is so much to consider. I wish a professional was doing the job! |
| You will get less 'fumes' using a "professional use only" waterborne polyurethane, such as Traffic by BonaKemi or an equivalent product. Sanding and preparation will be very important...finish hides nothing. Machine use requires knowledge, skill and experience to get a near flawless result. Dust control is also important. Any dust left on the floor will interfere with the appearance of the finished floor. The flatter and cleaner you get the wood surface before applying anything, the better the final result will be. Vacuuming is very important...sweeping alone is not enough. Finally, there are no 'shortcuts' when finishing a floor. You must follow all the preparation steps and application rates and dry times. Again, good luck. |
| I just did my floors with great results using Bona. You stain with an oil base wipe let dry overnite. You don't have to use a sealer, 2 coats with a lite sand in between and you will have great results. The only downside is the Bona is expensive. Check it out at: |
- Posted by lindarenee (My Page) on Wed, Apr 6, 11 at 21:26
| Thanks folks, I'm leaning toward the Bona Traffic and believe I have my husband talked into using it if I buy it. Seems worth it to me. He has already purchased oil based polyurethane but it can be returned. The people on the Garden Web forums are the best. I appreciate your help! |
- Posted by greencleaning (My Page) on Wed, Apr 6, 11 at 22:56
| Keep rags handy to wipe up any excess. The pigments of the stain are in suspension, not in solution, so the stain must be stirred regularly during application. Be sure never to store oily rags together. There is always the threat of spontaneous combustion. |
| "Do you want to go toxic or non-toxic? Check out the different finishes with Polyurethane versus Tung Oil." Is this a joke? Even tung oil based finishes are pretty far from "non-toxic." Try reading a few labels. |
| We're refinishing our oak floors. Previously had polyurethane. 8 years ago we had some water damage (20 sq ft) and rather than just fixing one small area we had to refinish a whole big area (400 sq ft) -- because the flooring ran from the kitchen through dining nook to family room. This time around we checked out samples of finishes at a reclaimed flooring store and got hooked on the idea of using hardwax oil. We got samples of Woca (oil) and Osmo (hardwax oil) -- both European products. We like the look of them because it doesn't create a "plastic-y" film like poly does. It's a bit truer to the wood (in my opinion). This type of product also has as an advantage that you can fix one area if there is damage or it needs maintenance rather than re-doing the whole floor. Of the two products we liked the Osmo much better because it had more "solids" in it and seems like it will protect the wood better. http://www.osmona.com/ A very supportive / responsive online retailer for Osmo is in Deleware (I'm in California). If you're interested, check out their web site and get some samples to try on wood scraps. It's actually pretty hard to find in stores--even in a major metropolitan area like L.A. http://www.worldclasssupply.com/products/OSMO.html Good luck! |
| This guy has a blog and is researching the different oil finishes. Here is one and you can find the first on this site. He's testing a third one in the next few weeks: http://napervillehardwood.com/blog/ I spoke on the phone with the owner (who called me back immediately). He can't help us because we're out of his area, but man was he helpful! Just a wealth of information and said I could email if I had any more questions. And this is from a guy who can't get our business. Impressive. |
| "Do you want to go toxic or non-toxic? Check out the different finishes with Polyurethane versus Tung Oil. " Do NOT try to drink the "non-toxic" tung oil. |
Return to the Flooring Forum
