Return to the Flooring Forum
removing dark urine stains from hardwood floors
spinachqueen (
Tue, Mar 20, 12 at 21:53
| How do I remove dark urine stains from hardwood floors. Our dog has been urinating on a rug under table and I've just discovered it. Any advice? It's really dark! |
RE: removing dark urine stains from hardwood floors
| You can't. You will have to replace the stained material. |
| You may be able to sand down to unstained wood and re-seal. |
| "You may be able to sand down to unstained wood and re-seal." The problem that usually shows up is that the urine can penetrate at the joints between the strips of floor, and you simply cannot 'sand out' enough to remove the staining that came in from the edge of the strips. If it is a small area you can remove strips and replace them. If the floor is old look at closets fr a ready source of matching wood. The new wood in the closet will not show as badly |
| Thanks for your advice. This is depressing! We'll just have to see how it works out. |
| If the floor was NOT prefinished, then the cracks should be sealed and the urine will not have gone down between the planks. Rent an orbital sander and test it out - it's not expensive to rent one for the weekend, then you can reseal it if you are successful in getting down past the stains. |
| "If the floor was NOT prefinished, then the cracks should be sealed and the urine will not have gone down between the planks" A site finish does not seal the floor longer than the first heating season. The wood shrinks, and every joint opens slightly. |
| From my one-time experience in fixing a urine stain on a hardwood floor which was site finished (renter's litterbox leaked and had no mat underneath), it was easy to sand down past the stain and refinish. So I think there is at least a chance that this is easy to fix. I would certainly try the sanding down before ripping it out and replacing it. |
| You could sand all the way to plywood and never get the stain out. Just sayin' Remember the sandable thickness is only about 3/16 to 1/4 of an inch. At that depth you hit nails/staples in the tongue. |
