What to put on chair/table legs to protect wood floor?
Posted by manzanita (My Page) on
Sat, Mar 10, 07 at 21:45
We've just completed installing a bamboo floor. What should I put on table and chair feet to help protect the floor? When I had Oak flooring a few years back, it was recommended to use wool "felt" on the feet. Is that still the case or is there something better?
This is at the beach and we knew the risks of installing wood and sand but it still seemed like the best option for the house.
RE: What to put on chair/table legs to protect wood floor?
I did not see what the links above pulled up (probably what I am going to describe)but go to Lowes or Home Depot. They have several options. For chairs and other furniture with legs, they have various sizes of plastic disks with a special sleeve mounted to them to hammer into the bottom of the legs. The nature of the sleeve makes it so it WILL NOT split any wood, they remain securely fastened and are ideal for furniture that is moved often like chairs and I have used them on some pretty nice antique pieces with no problems (when you see the construction, you will understand better). These disks are covered with a dense wool felt. For other pieces (those that are not moved often), they have peel and stick pieces that can be cut to size and adhered to the bottom of furniture. In each case, the felt lasts forever. We have had some for 15 years that are still in good shape.
