Mon, Mar 21, 11 at 17:46
| I have engineered wood floor that I clean with Bona cleaner. You spray the Bona onto either the floor directly or onto the microfiber pad.
I'd like to try one of those new spray mops by either Libman or O'Cedar. the are like the Swiffer spray mops, only you can use whatever cleaner you want. Do you think the Bona cleaner would work in either of these two mops? I've already posted this on the cleaning forum. TIA,
| yes they'd do fine using the bona spray. I just bought a gallon of Bona at Home Depot and they sold a bona 'swiffer' that sprayed the liquid before you mopped. Normally just doing it dry works just fine and use the spray only on spots or soiled areas. The mops you mentioned are both fine. |
| Thanks, boxer. Did you happen to notice if the Bona "swiffer" is refillable? I don't think it is, and that's why I'm avoiding it. Ellen |
| The tank for the fluid is. The mop is microfiber so you just throw it in the washer. |
Return to the Flooring Forum
