JOIN NOW LOG IN
How to fix this floor?
Posted by jsweenc (My Page) on
Sat, Feb 6, 10 at 22:20
We are renovating and have moved some doorways around. One new doorway opens up in the very center of the oldest part of the house. The settling of the house (red clay region) has caused the center (beam?) to rise up. I have noticed the elevation change for some time, but it never struck me as a problem until we had this doorway knocked out.
One day when I was away, GC was filling in the gap in the threshold on the floor in this doorway. I arrived home before he got too far. He was planning to fill it in and cover them with a raised strip of wood. We have had these strips elsewhere and find them problematic, so I asked if he could find one strip of nice wood to put in there instead. He said he would try, and it would save him from having to do what he was doing.
He didn't mention (can't imagine that he didn't notice) the difference between the two floors from one space to the next. The more even floor is newer construction.
I don't think I want the old floor sanded down enough to match the newer part. But I also don't want a raised strip of wood to trip over. It is our new path from garage to kitchen and will be frequently traveled by all.
Any other suggestions for how to fix it and make it look decent?
Foreground is newer construction; elevated floor is older
Older section is on bottom of photo; newer on top
Thank you for any help you can give!
RE: How to fix this floor?
Have someone fashion a reducer for the space. You have less than a 3/4" height difference to deal with. You will hardly notice the difference. Think of this 5" width reducer as a mini ramp. We do this kind of thing all the time. The top of the reducer is made flush with the top of the higher flooring and the trailing edge (about 1/8") sits on top of the lower flooring. No tripping hazard at all, unless you shuffle around, rather than lift your feet as you walk.
