Any mop to recommend to clean laminate & tile floors?
Posted by janesylvia (My Page) on
Wed, Feb 6, 13 at 19:11
We bought a house and will have laminate flooring installed. What mop can you recommend to clean the laminate floor and tile floor in the bathrooms?
Thank you very much.
RE: Any mop to recommend to clean laminate & tile floors?
Unfortunately, a sponge mop or Swiffer will move the dirt and grit around and get trapped in the grout lines. Use only a string mop and change any dirty or even cloudy water. If the final wash isn't with clear water, you'll get hazing on ceramic tile. A swiffer is probably OK for laminate...
I use water and vinegar for my tile and laminate. I use a mop with a removeable microfiber cloth. I take it off, soak it, wring it extremely well, mop and repeat when needed. I vacuum first before mopping (my vacuum has a bare floor setting). I think I got the mop at Lowes or Bed Bath Beyond. Main thing with laminate - do not spray anything directly on it and make sure any mop you use is wrung out very well. You do not want to saturate the floor.
Microfiber. The old ways/products are good, but innovation and technology makes them better.
Here is a link that might be useful: Microfiber Swivel Household Mop
Steam mop will work, you dont want to regular mop laminate.
