Is it OK to not use tapping block?
Posted by wijody (My Page) on
Sat, Feb 26, 11 at 11:42
And just strike the wood on the tongue or on the edge?
Also, when trying to fit tongue/groove click flooring around a hard to get to area (against wall with doorways) is it OK to shave off the click part with a razor and then use urethane glue from a caulk gun to glue the floor together?
(this is Teragren flooring, Synergy floating strand bamboo in Java)
(My third topic recently - sorry - I just really need advice)
RE: Is it OK to not use tapping block?
Just to clarify, they are using a rubberized mallet when hitting the boards (though they do seem to be making slight 'delamination' type marks along the edges here and there - at least, I assume that's what the marks are from. (?)
The block is intended to reduce damage to the edges that will show after installation.
It is even more important with pre-finished material since there is no sanding/finishing step to possibly remove any slight damage.
Thanks - so I'm not sure if I should tell the installers I didn't appreciate them not using one? Is it standard practice for a "pro" not to use them?
If the manufacturer installation guideline says to use a tapping block, then they are installing your floor improperly. What does the manufacturer say?
It is fine to shave a little off the clic profile and then to glue the pieces. That is how it is done with most floating panels to secure them when encountering work arounds.
