Return to the Flooring Forum
cleaning laminate floors
Wolfpackmom (
Sun, Jan 27, 13 at 13:37
| I have click - floating - laminate floors. Have had them about 10 months. Sorry I got rid of carpet. I cannot keep these floors clean. Salesperson and installer warned me NOT to use a steam mop, so I don't. I currently use vinegar and water and a cloth mop. This takes me forever-there has got to be a quicker easier way without ruining the floors. Any suggestions??? |
RE: cleaning laminate floors
| Swiffer mop can do my living room/hallway in 3 minutes flat. can use solution if you want i do about every 3rd cleaning. They make premixed solution you can get at home depot/lowes or you can use the vinegar solution as well. |
| Thank you for your message. I may be way over thinking this and may be a little paranoid about ruining the floors too. A friend is having her kitchen tiled right now because her laminate was a mess. The installer told her that he could tell she was using excess moisture when cleaning her laminate because it had moisture damage to it (not from being on a cement slab). She has used a steam mop and some sort of mop that sprays the liquid out. I just don't want to end up in her position. If you only use solution every third cleaning, what do you use the other times? |
| Dust mopping is all that should be done as 80% of the regular maintenance. Then a plain damp mop, dampened with a standard wood floor cleaner like Bruce or Bona. Damp. Not wet. If you can wring water out of it, it's too wet. After dust mopping. |
| My biggest issue with them being dirty is footprints and pawprints. They are everywhere and I can't stand to look at them. Dust mopping doesn't get rid of them. I have had carpet for years and now thinking about it - how dirty it must have been even though I had it professionally cleaned several times a year. If I could turn back the clock to April, I would have put tile in a lot of the places I put laminate. I have had a hard time finding a dust mop that I like and a mop for using with cleaner. |
| One third cup of amonia one gallon warm water. Damp cotton mop.Every six months. Dry dust mop daily. |
