Resolute accaim problem
Posted by victory_tea2085 (My Page) on
Mon, Dec 8, 08 at 22:50
About ready to ditch it as I have replaced countless parts- very expensive parts. Am thinking of just removing the combustion package as it sells for well over 200 dollars and I have replaced it once in the 9 years I’ve had the stove. It is fragile and just breaks down with normal use. Has anyone else simply removed the combustion package and what effect did it have on the overall heating of the stove? Thanks- Paul
RE: Resolute accaim problem
how close is the firedepartment from you house?
An 8th of a mile, why do you ask?
One guaranteed result of removing parts is that it will void the manufacturer's garantee that the stove will operate safely, the certification by a testing agency that it operates safely, and likely enough coverage by your fire insurance carrier if a fire results after your modifications to the equipment.
What is a firedepartment? Don't see it on the exploded schematic of the Resolute- Acclaim.
