Looking for expert advice for adding insulation under a gas firep
Posted by MileHigh80228 (My Page) on
Sun, Dec 9, 12 at 8:32
Hello,
Newbie to the forum here. I'm looking for some advice regarding insulation below a gas fireplace.
We recently remove a large brick hearth. As you can see there is no insulation under the fireplace . The cold air comes in unabated and we would like fix that.
The three areas under the fireplace that need attention are all made entirely of wood (2x on 3 sides and 3/4" plywood on the top).
My understanding is of course wood has a much lower combustible temperature than either fiberglass or rock wool insulation. Is there any reason that I can't simply insulate the three cavities with product (non-paper faced) from the local home improvement store?
The town home was built in 1985. I'm unable to find any brand info/model number/specs pertaining to the fireplace.
Thank you for your thoughts and advice.
RE: Looking for expert advice for adding insulation under a gas f
Spray foam where the rim joist meets the floor as well as anywhere you feel a draught from the exterior wall. Hold a lit long candle lighter and you will find where the air is coming in. Then fill the void with Roxul rock wool insulation. Your good to go.
I wouldn't be concerned with ignition of the lumber below, the unit looks to have a nice refractory lining, most units today so not.
