Is there a compromise between a fireplace and an insert?
Posted by sjbgarden (My Page) on
Mon, Nov 29, 10 at 21:53
My husband and I love wood fireplaces, the look, feel and smell. We also understand the practicality and efficiency of a wood-burning stove. We would love to investigate a compromise and don't know were to start!
Some people recommend an insert, but the window you look through is still so small!
I miss looking into the fire and hearing the crackling of the wood, but I do admit, the warmth the stove kicks off is unquestionably efficient!
Is there such a thing as the best of both worlds?
The fireplace/firebox is large, it really is a shame to close it down!
Photo link below.
Any thoughts?
SJB
Here is a link that might be useful: Link to my fireplace photos
RE: Is there a compromise between a fireplace and an insert?
I recently purchased/installed a Hearthstone Clydesdale insert (which I'm pretty happy with) and the window is fairly large (about 20in wide x 12 in high) and you can purchase a screen which allows you to leave the door open safely.
If you do not want to install an insert, there is an alternative, but you will need to do some searching, because I do not have specific information about it. The device I have in mind, invented by a physicist, is a specially designed iron crate into which the wood is stacked in a certain specific way. The advantage of the system is that much less heat is lost up the chimney than with a conventional system. So it is much more energy efficient.
If you cannot find anything about this from searching the web on your own, go to hearth.com. They have a forum of fireplace experts who might be able to guide you.
