Fri, Nov 18, 05 at 20:34
| I have a 99' Whitfield Advantage Plus pellet stove and the flame licks up the firebrick and appears to go up the pellet chute. When I put the stove on 4 or 5 it is even worse. Does anyone know if the burn pot goes in with the slot in the rear or the front? |
- Posted by brad_brown2 (My Page) on Tue, Nov 22, 05 at 7:37
| I've got a Quadrafire stove, but on mine the burnpot "slot" goes towards the rear, where the chute comes down. My fire pattern sort of jumps all over the place. Do you have a local Whitfield dealer with a stove display where you can actually see one of their stoves burning and compare it to yours? You might find out that what you are seeing is normal...or abnormal - but it's hard to tell unless you either have the dealer take a look at it, or see another stove like yours burning. |
| Our St. Croix does a similar fire dance too. Has not caused any problems so no worries here.
| I just purchased a Whitfield this year. My flame also leans back. Have had no problems yet. The slot that I think you are referring to goes in the front on my stove I have a special tool that fits this slot for easy removel. |
| Generally, if the flame goes up the chute, you need to adjust the damper some... on a whitfield, it's on the side. pull it out a little and see if the flame changes. |
