| We have a Marquis Infinite, 33,000 BTU direct vent gas fireplace inserted a few months ago, as part of a big renovation. There's a TV above the fireplace, and we have been taking our time deciding what to face the wall with.
We finally turned the fireplace on the other day, and after about an hour, the area immediately above the fireplace (which is cement board right now), got so hot, we could barely touch it. We definitely know that the fireplace has been properly installed. We recently ordered textured glass which the contractor has said he will make tempered, however, he can't guarantee that it wont brake due to the heat. Help!!! Has anyone faced their fireplace with tempered glass products or had any concerns with overheating right above the fireplace? |
| I took the time to download both the installation and Operating manuals for that fireplace,Yet---- I still can't see where the heat comes out of this fireplace, other than the front glass! Is that the case? If it is, there is little you can do as far as keeping the area directly above the fireplace cooler. I had bought a Valor, but it has a large vent above the glass area, where most of the heat exits. When I first installed the fireplace I was told I did NOT need a fan kit for it. There is a good possibility that the TV repair man may become part of your family, as that heat sure won't do the Assuming I am right about the way heat exits your fireplace, (I hope I'm not) there is little you can do to Sorry I can not help with the glass or other type surround. I hope you are able to find a fix that not only appeases your sense of decor, but one that will not fry walls or TV. Gary |
