| Hello everyone,
I am new to this forum but see alot of pellet stove talk. I just installed a Harmon P68 and was wondering if anyone has been able to hook up a programmable thermostat to a Harmon pellet stove.
- Posted by pellethead (My Page) on Sun, Nov 25, 07 at 22:35
| originally posted by someone on hearth.com Ive noticed a few questions awhile ago about setback thermostats and pellet units. Harman just came out with a Technical Bulletin concerning them, and I thought Id take this time to communicate it before I forget all the particulars. All Harman pellet units can utilize a setback thermostat. The thermostat must be: 1. Millivolt compatible Harman reccommends the following Honeywell units for this use: RTH230B If there is a jumper between Rh and Rc, it must be removed from the terminal block of the thermostat. The thermostat must be connected in series with the room sensing probe using the Rh and W terminals of the thermostat. Except with the P38, which has no room sensing probe, the set-back thermostat MUST be used in conjunction with the room sensing probe. there are two modes of operation as well: Occupied Mode: (someones home) Unoccupied Mode: (noones home) Consult your owners’ manual for a description of the 4-blink status. This error occurs when the contril board senses the room sensing probe isnt connected or has failed. This happens with the thermostat in series, since when the thermostat opens (is satisfied), there is a loss of continuity in the room-sensing circuit. The 4 blink status automatically resets when the board recognizes the room-sensing probe has been reconnected (ie: when the thermostat closes and calls for heat). Anyhow, here’s the gist of the tech bulletin. If it sheds some light, great. |
| Thanks pellethead. I tried this tonight with a Hunter model #44260 programable thermostat. I did get the stove to respond however it worked in opposite of the way intended. When the thermostat called for heat the stove would enter 4 blink fault, when the thermostat was satisfied the stove would reset the fault and turn on. Any thoughts on what might be wrong? I thought I had it figured out when I switched the thermostat to cool mode thus reversing the action but I had the same results. Thanks in advance. |
