Wood Stove pipe - triple pipe question
Posted by offgridnatureman (My Page) on
Wed, Nov 12, 08 at 10:42
I am installing a stove this weekend in a geodesic, sloped ceiling and roof greenhouse.
It's not a typical wood stove intall.
It involves a straight up around 14 feet, of my 6" single wall, then needs to go through a 1/2 inch thick polycarbonate glazing that is angled. There are wood struts a foot away that I am building a frame on.
I have studied all the kits available, and do have a guy experienced with stoves helping me, but I am trying to get as much info as possible before we start and before I start buying the parts needed.
My main questions are regarding triple wall pipe for the actual penetration.
All diagrams seem to show the triple meeting some sort of box under the ceiling. I am worried this is to close to my combustable (meltable) ceiling.
Should I run my triple a foot or so under the ceiling before connecting to whatever frame I end up going through?
Then - once above the ceiling and onto the roof, to get two feet above the peak of the roof, I need about 4 feet of pipe. Should this ALL be triple, to the top, or can I go a couple feet of triple above the roof, then another two foot section of single wall to top it out? Meaning if I went a foot under, and 2 feet over, a standard 3 foot chunk of triple would work?
Thanks for any advice!
AC
RE: Wood Stove pipe - triple pipe question
I previously lived in a dome home and had the same problem. I am now in Colorado and our building code may be a bit different than yours. Triple wall pipe is no longer allowed in Colorado - - instead we use a insulated stainless steel two wall pipe (insulation between the 2 walls) Anyway, in Colorado, you have to be to the "fire protection" pipe (2 wall stainless) before going into the ceiling. You should have some sort of "ceiling box" that will be attached to your roof/ceiling that will penetrate your ceiling. It will actually support your pipe going thru the ceiling and further up. The pipe above the ceiling box should all be 2 wall pipe (maybe 3 wall in your case). I would suggest you contact your local building department to check the code since they are the ones that will approve/disapprove your installation.
