Need help with Fireplace/ gas starter.
Posted by rysox (My Page) on
Wed, Nov 21, 07 at 0:00
Ive never owned a fireplace before moving into my latest address. It has an older fireplace, vented thru a chimney and what also looks like a damper/vent on the side of house.
It has a gas starter I believe, which is turned on and off by a key type tool. There is no standing pilot light. The damper is closed. and there is a vent thats opens and closes into the living space.
I havent tried to use it yet, I just vacuumed out the old owners mess from inside.
How do I use such a fireplace? And I am concerned about its safety since it has a gas starter. Please advise.
also,
RE: Need help with Fireplace/ gas starter.
This would be a wood burning fireplace with a gas starter used to start the wood fire. Place the wood on the grate first, then get you one of those long handle butane lighters. Ignite the butane lighter, hold the flame even with the flame ports on the gas starter and turn the key. Once the wood starts burning turn the key off. I assume this fireplace has doors of some kind and the vent into the house is for air into the fireplace. The damper needs to be fully opened before you start the wood. This is a basic example and one would really need to see your application before given exact advice, you may need someone to come over and look at it, don't be embarrassed to ask, everyone had to be taught to do everything they know how to do.
