Fireplace Insert - Propane or Electric
Posted by windrunner (My Page) on
Tue, Oct 14, 08 at 14:03
looking at options available to fill an existing fireplace at cottage...
currently have a wood burning insert and want the convenience of either propane or electric...
the room is 16x12 and the smallest propane flush mounts generate 20,000BTu which i think would be overkill...
never considered an electric fireplace until it was suggested....
so i would like to get people's opinion why they either went this route or why they declined this option...
as well, what are the top manufactures...
thanks in advance...
windr
RE: Fireplace Insert - Propane or Electric
Propane has the advantage that it can be used when there is a power failure. But I understand your concern about getting an insert that produces too much heat. Shop around some more -- you might find one that throws out less heat.
Make sure you get one with Direct Vent tachnology. Do not get a ventless system. They are dangerous and against code in many places.
