Sat, Oct 6, 07 at 12:48
| We are having a problem with our new Napoleon Fireplace NZ6000. The glass fogs then burns on. We have to scrape it off with a razorblade. |
| Your wood probably is not dry enough, or your dampering it down to much. Not familiar with that model and assuming it's a wood burning fireplace that is. |
| yes your wood is wet try leaving the door crack opened a little when you start it up after it get going you can close it up. |
