Fireplace - Electronic Ignition
Posted by jy1999 (My Page) on
Tue, Oct 16, 07 at 2:40
I have a natural gas fireplace which is having problem in igniting. I have replace it with a Honeywell S8610U Universal Intermittent Pilot Module. But the fireplace will only start up and lit for about 2 sec. and then shut off and start again.
I have checked all the grounds and connection and they seems OK. I am just wondering if the ignitor/sensor is the problem. Is there a way to check the output of the senor wire to the module ? The fireplace was lit and I assume the ignitor or spark is ok.
Thanks in advance for any advices.
RE: Fireplace - Electronic Ignition
Yes, there is. You need to measaure the DC microamps flowing from the ground connection to the module.
A typical read would be 10-15 microamps, but the pilot will usually prove with 3-4 microamps.
On some of these you can run a wire from the pilot flame to the sense port and see if it works too.
