| I have a fireplace that was originally designed for wood burning. The previous owner ran a gas line to the fireplace and put in one of those little gas logs contraptions.
I want to take out the gas logs so that we can have a real wood burning fire again. There's no longer any gas going to the fireplace as the line was cut and rerouted to the kitchen for a gas range (however, the old gas line is still stubbed out in the fireplace). Do I need to remove the old gas pipe? Put a cap on it? What about the hole the pipe enters through? What's the best way to seal it off? Thanks. |
- Posted by mrblandings (My Page) on Mon, Sep 24, 12 at 17:25
| Not an expert here, but I would guess you would at a minimum need to remove the pipe and fill the hole with refractory mortar. A local chimney company should be able to give you a definitive answer and be able to do the work in a way that would satisfy your local inspector. You'll want them to inspect your chimney before doing anything, and this may turn up other problems if it hasn't been used or maintained for many years. While you're considering this work, you really should think about putting in a wood burning insert instead of burning directly in the fireplace. The insert will burn much more efficiently and will give you far more heat than burning directly in the fireplace. We just put an insert into our fireplace and it's really made a huge difference. |
- Posted by christopherh (My Page) on Tue, Sep 25, 12 at 7:06
| I definitely agree about the insert. Fireplaces have a "negative efficiency" which means they will take heat out of the home and up the chimney. That's probably why the unit was converted. Today's modern inserts can be damped down to a point where you can see a lazy flame which can be very relaxing. They're very efficient too. And clean burning. |
