| Hello,
I have a wonderful Morso 2B stove, probably from the '80, although I don't exactly know. The cast iron baffle inside the combustion camber is holed and partly collapsed and needs replacement. The replacement is difficult to locate and probably expensive. The part is 1/4" thick. I am wondering if a 3/8" thick steel plate could withstand the heat or if I really need that part in cast iron. Thank you for your attention. |
- Posted by mainegrower (My Page) on Wed, Sep 6, 06 at 7:08
| If there is any mechanical connection (including stove cement) between the cast iron and steel, the differing rates of expansion and contraction will quickly become a problem. Gaps will open up and I would think that the steel would also be much more prone to warping. I would contact the Morso company or a reliable dealer/repairer for advice. |
- Posted by commonground (My Page) on Wed, Sep 6, 06 at 8:15
| The part I need to replace is a smoke shelf inside the combustion chamber that is not cemented to the sides of the stoves but only rests on small lugs inside the stove. ...that the steel would also be much more prone to warping... I think there lies the problem as I don't know how much more the steel is going to warp compared to the cast iron as it is directly exposed to the flames. This was my actual question to the members of this list. I am hoping to get away with 3/8" steel instead of the original 1/4" cast iron but I don't know. If somebody knows the answer please tell me. Thanks again Thierry |
| Were you able to solve this problem? How? We have the same one/ Thanks |
