| I am putting in a 65000 BTU wood stove with a 6 inch flue. This will be replacing a Heatilator which has a triple wall 12 inch O.D., 8 inch I.D. steel chimney. Could I use a 6-8 inch adapter from the stove to the chimney, or do I need 6 inch pipe all the way out? This is a 15 foot straight vertical chimney.
The place I bought the stove is telling me I need 6 inch all the way. I'm thinking that I can use an adapter from the 6 inch stove pipe to the 8 inch chimney pipe. Rich |
- Posted by christopherh (My Page) on Thu, Jul 28, 11 at 7:15
| You need the 6 inch all the way up to maintain a proper draft. And there should be insulation surrounding the insert to maintain heat in the flue to keep the draft. |
| What type of insulation material? Vermiculite? Looks like I am going to need the 6" all the way. The current Heatilator doesn't appear to be rated for 2100F. |
- Posted by christopherh (My Page) on Sat, Jul 30, 11 at 6:39
| The brand name is Kaowool. It's a white ceramic fiber insulation and is used in places where heat is a concern, like power plants. But why are you looking at 2100 degrees? The normal surface temperature of a well running stove is +/- 600 degrees. And today's modern stoves either use a CAT or secondary combustion to retain the heat and prevent that heat from escaping up the flue. Lost heat is lost money. What brand is the stove? |
