Masonry fireplace
stoveguyy
LIVING ROOMSHow to Convert Your Wood-Burning Fireplace
Learn about inserts and other options for switching your fireplace from wood to gas or electric
Full StoryFIREPLACESRumford Fireplaces Are Hotter Than Ever
Higher efficiency and good looks are leading homeowners back to this 18th-century fireplace design
Full StoryEXTERIORSSkip the Brick for a Statement-Making Chimney
Clad your chimney in metal, concrete or masonry for a dynamic architectural element and a most contemporary design
Full StoryMATERIALSRaw Materials Revealed: Brick, Block and Stone Help Homes Last
Learn about durable masonry essentials for houses and landscapes, and why some weighty-looking pieces are lighter than they look
Full StoryREMODELING GUIDESModern Metal Fireplaces Open World of Possibilities
Allowing way more natural light than traditional fireplaces, and with some not even needing a vent, metal fireplaces are a major improvement
Full StoryDECORATING GUIDES10 Inspired Ways to Refresh Your Mantel Now
Postholiday blahs don't stand a chance on your mantel when you incorporate these ways to accessorize and light it
Full StoryFIREPLACESWhat Goes With a Redbrick Fireplace?
Play up or tone down your redbrick fireplace by pairing it strategically with other colors and materials
Full StoryREMODELING GUIDESHerringbone-Patterned Firebrick Takes Style to Hearth
Fireplaces cross over into craftsmanship territory when the brick inside is laid in this graphic pattern
Full StoryGREAT HOME PROJECTSHow to Remodel Your Fireplace
Bring your fireplace design up to snuff with this makeover lowdown
Full StoryREMODELING GUIDESClean-Burning Woodstoves Ignite a Greener Heating Trend
No need to rely on oil or gas to heat your home — new woodstove designs burn cleanly and are beautiful to boot
christopherh
Ponteix
Hockessin Fireplaces · Charleston Interior Designers & Decorators · Champaign General Contractors · DeKalb General Contractors · Delhi General Contractors · Eatontown General Contractors · Elyria General Contractors · Endicott General Contractors · Great Falls General Contractors · Jacksonville General Contractors · Los Alamitos General Contractors · Perrysburg General Contractors · Renton General Contractors · Riverdale General Contractors · Palm Springs LightingstoveguyyOriginal Author
