Mon, Jun 30, 08 at 7:03
| I am in the process of removing the 1980s fireplace surround that goea all the way to the ceiling. It is slow going but I hope to be done by next weekend.
Above the mantel I am planning on having just drywall but what should I have under the tile that is to around immediately around the opening? I don't know what burns and what does not; so what do you suggest? |
| You can get fire-rated sheetrock. But you shouldn't have temps outside the chimney that would cause inflamination--surely there's still brick or stone there, or adequate space around the metal flue. |
| I am in the process of pulling the brick off the fireplace. I would like to put tile around the firebox but should it adhere to? |
