Catalytic Wood Stove
Posted by stonehouse24 (My Page) on
Sun, May 31, 09 at 21:19
My cousin has offered me his Vermont Castings cast iron wood stove (10 years old+/-). It is a small catalytic model. However, the catalytic unit needs replacement (expensive). I plan on only using the stove on an intermittant basis (2X/week) to help heat a workshop. Can the catalytic unit be removed or bypassed? Will the stove still burn wood ok without the catalytic unit? Any advice/information would be appreciated.
RE: Catalytic Wood Stove
The Cat is there for a reason. And that's to make the stove burn clean. Without it you have a "Smoke Dragon". The cat burns off the smoke (unburned HEAT) and therefore the air is still clean. Cats aren't THAT expensive, so replace it and enjoy.
Can you access it to clean it? My father-in-law has the Vermont Castings and cleans his catalyst every year.
