Fireplace Maintenance
Posted by shelor (My Page) on
Sat, May 16, 09 at 11:43
When burning a fire in my brick fire place, smoke goes into the garage. Do I need to re-seal the bricks inside my fireplace or the bricks in the garage. If so, what do I use or do I need to hire someone to do this?
Thanks,
RE: Fireplace Maintenance
I suspect that the liner in your chimney vent has corroded or developed a crack. You should have it looked at by a chimney expert. (When was the last time you had it cleaned?) The probable solution will be to install a new liner. I would get 2 or 3 opinions on this from contractors you independently find out about to make sure they are honest and competent. You don't want to spend a lot of money only to find you're back to square one.
