Sat, May 23, 09 at 5:46
| I don t know why this is but hope someone can help with my problem. This is a old field stone fireplace with a clay liner . I want to put a 6" stainless steel liner in for my wood insert. I cannot bring this liner down all the way because one of the clay liner is of set from the other if I was to break one side I would have enough room but this is out of my reach about 4 to 5 feet from the botton up and there is nothing supporting this side of the liner from what I can see I was told it s best to have a liner all the way could there be another way. Thanks Mark |
| Most larger chimney service companies have special equipment to remove the tile stack. You will also need to insulate that stainless liner when you remove the stack. Some of the liner companies make an oval liner that might work for you with out breaking the tiles. What ever you do don't install the insert with out the stainless liner, it violates fire code, will probably not allow the insert to work correctly and may result in a chimney fire. |
