Mon, Apr 13, 09 at 21:03
| I have a small rambler, on the back of it there is a small family room. There is a small door going outside. I wanted that door to be either completely closed with drywall or put a firplace in the openning. What would be approximate price to put in electrical vs masonry FP? |
- Posted by haus_proud (My Page) on Fri, Apr 17, 09 at 8:59
| For an estimate, you need to have a trained, experienced installer look over your particular situation. Generally, an electric system would probably be a lot cheaper because it could be a prefab. If you put up masonry, the cost would be higher, but then you could get a lot more heat, depending on the kind of system you put into the masonry fireplace. But is atmostphere and a pretty flame is your first priority, and you do not need a lot of heat, electric might be the best option. |
