Wed, Mar 4, 09 at 17:06
| My gas valve leaks through the key hole, but only when the gas is turned on. Is their a way to repair the valve without removing the mantel, tile, etc? |
- Posted by seattlepioneer (My Page) on Sat, Mar 7, 09 at 17:16
| Remove the bezel that covers the hole in the wall by turning the beze counter clockwise, which unthreads it from the gas valve. Once it's removed, use a flashlight to examine the valve. Often the wall shutoff valves have a packing nut on the front of the valve that works loose and causes a leak. You can use a spray bottle of water and a lot of dishwashing detergent to diclose the leak. Tighten the packing nut clockwise a bit until the leak stops. |
- Posted by pyromaniac (My Page) on Mon, Mar 9, 09 at 17:21
| Thanks for the info. I'll give it a try. |
