close up fireplace vent
Posted by yarch (My Page) on
Mon, Mar 7, 05 at 13:13
Hi,
I have an old fireplace (brick) that has a metal insert (heatilator) in it. it must've been put in 50 years ago.
there are 2 vents on each side. the bottom vents on each side are the intake and the top vents on each side throw out the heat.
i would like to close up these vents with brick/mortar. is there a problem with this? what would happen to the trapped air behind the metal insert and the brick fireplace?
RE: close up fireplace vent
Heatilator is a brand of fireplaces.
I don't understand what you are referring to when you are calling something a "heatilator".
it's a heatilator in the sense that it takes in air through a vent, heats it and releases the heat through another vent. this is the general term i've had people refer to it as. this is a homemade "heatilator"
Can anyone answer the first question asked? Is it possible to close them up???
I have a similar set up and would like to close up these side vents so that I can build a nice fireplace surround around the firebox and drywall over the old brick at the top.
Heatilator was the first all-metal wood burning fireplace with an airspace between two heavy steel shells. There was an option to attach ducts to openings in the top and bottom of the steel shell so that air could move through it by convection. As I recall the vents were not required for safe operation but you should do some research to be sure.
