Scott Pellet Stoves
Posted by cocolallakids (My Page) on
Tue, Mar 7, 06 at 10:19
I hear they no longer make Scott brand pellet stoves. My problem is we bought a used one not knowing this. (yes, we now know not to buy used ones either!) Until we can afford a new one we'd like to repair ours if possible. Every so often we get a puff of smoke out the back, under the hopper and it smells like burnt marshmellow. Any ideas on what causes this?
RE: Scott Pellet Stoves
I'll bet this happens most times during start up? There is an air inlet in that area for a kit you can buy to bring in outside air. If you can, hook it up to bring in outside air. Otherwise, put an extension on it to give the stove more time to suck it back in before it disipates into the room. You might want to check the exhaust flue to make certain it is cleaned also.
Most pellet stoves are basically the same and can be repaired quite easily unless there are special parts that need to be replaced. When I say special parts, I'm referring to things like the glass door, hopper door and things specific to the contours of the stove. Augers, motors, fan motors, thermostats and the like can be interchangeable albeit sometimes some retrofitting may be necessary.
I too got a Scott Stove, used, not working and free. I also got a spare fan motor, which turned out to be the problem. Now all I need is the manual. I would like to know what the "Auger Mode" button does. I know I need to push it one to get the auger to work.
Fan and auger motors are available through Rotom.
I have a Scott Pellet Stove that leaks smoke back through the hopper whenever I open it to add more pellets. Anyone know what causes this problem? Some times there is quite a bit of smoke, and I am concerned about the hazard of smoke inhilation while we are sleeping.
P.S. The auger mode button must be pushed everytime you start the pellet stove to start the auger. That is the only function it has.
Here's another thought on the smoke issue:
Actually, a couple - is the chimney clear, and large enough. Mine is 6" and goes straight up through the ceiling and roof above. I haven't had any trouble with it smoking.
Also - 2nd thought - have you ever removed all the firebrick in the top of the firebox? Could be that ash has piled up on top of the fire brick, and may be causing a pressure build-up in the firebox, pushing smke back through the auger when it is less than full.
I'm still looking for a manual for the Scott stove, if anyone has one.
Happy New year!
Gary
I now have the manual for the Scott Pellet Stove and have scanned it. If anyone needs a copy, email me.
Gary
hi gary, i need the manuel for the scott stove.
can you e-mail me at: jimmybalzamo@hotmail.com
best regards
Hi, I have and old guy I know he bought a used scott pellet stove. He needs a inst.book I worry he will not hook it up right. Any help please e-mail me ftaylor51@earthlink.net THANKS SO MUCH Freddie
Hi Gary, may i please have a manual too...thanks. gneegrneyez@yahoo.com and i was looking at buying a used Scott stove for 150.00 the guy says it just needs a heating element, do you think its worth it and can a heating element be located? Thanks so much! Jeannie
Anyone wanting a manual for a Scott Stove, and leads on auger motors and fans, please email me.
Gary-s If you still have a copy of the manual for Scott Pellet Stoves I could sure use a copy. sghowes@gmail.com
Gary-s If you still have a copy of the manual for Scott Pellet Stoves I could sure use a copy please my email is dkhill27@yahoo.com
Hi Gary I could use a manual to scott pellet stove also send to rtprince@netzero.com Thank you
Hello Gary. If the offer is still available I could use a manual for my scott pellet stove also. jerpadilla@yahoo.com is my e-mail. I live in Arizona and have been looking for parts to my scott pellet stove. Any suggestions? Need a fan and a blower. Thanks for your help. jparizona
HI GARY IF YOU STILL HAVE THAT OWNERS MANUAL I WOULD LOVE A COPY rwaite83@yahoo.com THANKS A BUNCH
