| My father wants to install an unvented fireplace in the family room, which is open to the rest of the house including the basement. Is there a problem with fresh air (does he need to open a window)? The house is approximately 1500 sq. feet, plus the basement. Should he go with vented?
What are your experiences with either? |
- Posted by seattlepioneer (My Page) on Tue, Feb 19, 08 at 23:22
| As a gas fireplace repairman, I declined to do work on unvented gas fireplaces. The risk of someone doing something that gets them injured, and then blaming me, even years later, was not a risk worth taking. In theory, if everyone who might use an unvented fireplace read, understood and followed all of the lengthy list of warnings and recommendations that came with unvented fireplaces, they would be safe to operate. But I've never encountered a single user who really understood the risks and warnings, and followed them. Because of that, they are too much of a hazard to recommend, in my opinion. |
- Posted by haus_proud (My Page) on Wed, Feb 20, 08 at 0:01
| Unvented degrade the quality of indoor air by depleting oxygen and putting fumes into the air. IMO, they should be outlawed and in fact are not allowed in sleeping rooms by building codes in many municipalities. Direct vent technology is the way to go -- a sealed firebox with 2 vents to the outside, one to exhaust the fumes, the other to draw fresh air to feed the combustion. They are expensive, but if you want the fireplace to heat, not just produce a pretty flame, it's the safe, energy efficient alternative. |
| Here is a post that I clipped a few years ago: ++++++++++++++++++++++++++++++++++++++++++++++ RE: B vent; D vent; ventless and which models??? (Follow-Up #1) First, DON'T install a ventless fireplace!!! Details below: Direct Vent Fireplaces offer the most features with respect to gas consumption, efficiency ratings and venting options. A direct vent fireplace will always have a glass window because these fireplaces are sealed systems using a double walled venting system. Combustion air enters the appliance via one section of pipe while fumes and moisture are vented through the other pipe. Most often, a double wall "pipe within a pipe" system is used. Subject to each model's requirements for distance and offsets, direct vent fireplace venting may be terminated either horizontally or vertically. Efficiency rating will average 65% to 84%, similar to ratings on gas furnaces. Keep in mind that these appliances must "waste" some of the heat produced to create a draft of rising warm air to evacuate the fumes produced without aid of a forced air exhaust system. Think of direct vent fireplaces as a decorative furnace: the beauty of a realistic flame with high efficiency. This appliance is great for primary or supplental heating and for emergency backup heating as most work without aid of electricity. Because this is a sealed system that uses outside air for combustion, direct vent fireplaces are usually the favored choice among those in the fireplace industry because of their greater efficiency and exceptionally reliable performance. |
