| Hi! Sorry if this has been asked already, but I couldn't find it on a Search...
The doors and some of the surrounding grill of our zero-clearance fireplace doors (converted from wood to gas) has GOLD metal trim (80's style!) I was wondering if anyone knows if it's possible to paint that same trim BLACK? If so, what kind of paint would you use and what sheen? I'd probably have to do it in place versus removing all the parts (or at least it'd be easier). I am hoping to update the look without having to replace the whole front panel. Thanks a million for your help! |
- Posted by justmejulie (My Page) on Mon, Feb 22, 10 at 21:55
| We did. We used a special high heat fireplace paint. Looks brand new now, no 80's |
| THANK YOU for the reply! Did you sand the gold areas first? (If so, just to rough it up OR to actually sand off as much gold as possible?) Do you remember what brand paint and/or where I should ask? (Home Depot? Sherwin Williams type specialty store? Fireplace store?) (I just hate to start something and be left a big mess on my hands!!) Thank you so much again! |
- Posted by haus_proud (My Page) on Wed, Feb 24, 10 at 18:01
| I think it would be a good idea to sand the surface first, and even then, there is a risk that some of the new paint will not adhere properly and may need to be redone. The reason I say that is because we had a black wrought iron table pedestal repainted professionally. We were told that they "abraded" the surface first by sanding it down before applying the new paint, which did not involve a change in color. I would therefore try to make the surface as rough as possible before putting paint on it. |
