Sat, Dec 22, 12 at 18:12
| I need some help. If I am in the wrong forum please advise. My husband has a custom butcher block (over 500 lbs.) and today I noticed a tomato sitting there on the butcher block. when I picked it up the bottom was black and there of course is a black stain on the butcher block where the tomato was. I have tried making a rub of kosher salt, lemon juice and rubbing. After that I put baking powder on the previous mix to no avail. It won't budge . is there anything else I could try? DH is out of town right now but i am going to be in hot water for sure. this block is his pride and joy. please someone out there take pity on me! any ideas would be appreciated! dixie |
| If you google 'removing stains from burcher block' there are a number of things you can try, including what you've already done which they say to leave on overnight. There are other remedies for you to check out, too. |
| you might try a dab of hydrogen peroxide, watch it closely and rinse when the stain is lifted. finish with whatever oil he uses on it to restore the finish. |
This post was edited by olychick on Sat, Dec 22, 12 at 20:11
| Is this an oiled finish type of butcher block? if so, then worst case you can sand it lightly with a very fine grit sandpaper in the direction of the grain, and then re oil. Before that I would try baking soda and lemon juice with a green scrubby. Then leave it sit for 15 minutes or so. I have oiled butcherblock, and the only thing I have ever had to sand out was Sharpie. I have removed wine, berries, and other food stains with the baking soda and lemon juice, or white vinegar. Also try regular table salt (finer grit than sea salt) with vinegar or lemon juice. Then touch up with oil. Butcherblocks are made to be used, so this type of thing happens from time to time. |
| I,m not sure what the finish is on yours so do at your own risk but I used Soft scrub with the bleach in it for blackberry stains . I know it does,t make any sence but it seems like the stains come up out of the wood and after a week or two disappear with the normal daily cleanings. |
