| Cross posting this in the Paint forum.
So I picked out the paint colors for my new construction house. The colors that came off the neutral paint strips? No problems at all. They look great. I can also live with the green and blue I chose for the bedrooms even though I'd like a bit more gray in both because they are not very far off what I was going for (but I'll probably re-paint myself at some point after we've lived in a bit if I still am not 100% happy). The family room/kitchen/dining room, however, are another story. I chose SW6668 Sunrise because I was going for a very sunny, South-of-France kind of look. The result resembles something more like Kraft Macaroni and Cheese. It would probably be fine in a small room but on such a large area, it's a bit much. I think really what I need is more of beige with golden undertones (and no orange at all). I'm kind of embarrassed not to have figured this out before it went up because I'm a graphic designer and I KNOW colors are always brighter when there's more of it. I also know yellow is very tricky. Alas, here we are, the painters are finished, and I just know I can't live with these walls. I am prepared for it to cost me to have them come back out and paint over it (and I'm a little annoyed that they they took down all of the tape and stuff before I OK'ed it, but that's another post). I'm just trying to figure out what would be the most economical way to do it. I don't want to have to (pay to) prime the walls again. I am tempted to just pick a color and stick it up on one of the walls and see if it works. If I had to choose right now, I would probably go with SW6128 Blonde. However, since it would be going over Mac n Cheese instead of white, I'm not sure. Any predictions on what kind of results I would get if I just tried to paint over this existing color? Should I go lighter and more muted than I think I want, knowing that this brighter color is underneath? Or maybe I should just go with Builder Beige and not worry about it. ;o) |
| I don't think you can count on it coming through the new paint in an even an acceptable manner. You've gotta cover it up, and it might take a lot of coats but there really isn't an alternative. I don't suppose you could tone it down with a white (or something bland) accent wall or two and just have less of the Kraft? |
| Thinking of primer as necessary to cover existing color is incorrect. Primer doesn't cover up color. Primer goes on 'sketchy' because it's primer and not a final coat. Many people think a coat of primer is supposed to be totally opaque, solid, and even. That's not how primer works nor is it what it is for. If you need a tinted/gray primer for the new paint color, you're going to need it no matter what the existing color happens to be. If the color you've chosen does not require a tinted/gray primer, then it's going to cover with the same opacity whatever color is on the walls - doesn't matter if it's off white or sunshine yellow. Coverage will be the same provided it's applied at the appropriate thickness and the recommended two full coats are applied. Changing your mind about a color after the walls have been professionally prepped is actually no big deal. Might have to pay to apply two additional coats but you've already paid for the prep. All the hard work has been done. If you don't like the color that went up, now is the perfect time to change it. It's like ripping off a band aid. Just do it and get it over with and once it's done, you'll feel better. |
- Posted by AnnieDeighnaugh (My Page) on Mon, Nov 26, 12 at 8:54
| I know they aren't as popular now, but have you considered a faux finish? I had an old bedroom with deep blue color on the walls that I tired of, so I got a wall paper border and put it up after I did a faux finish on the upper portion. It really changed the appearance of the room, and the blue became bright and fresh again. You may be able to just add a single color on top to change the whole impression of the wall color. For best effect, you can try for a subtle color change...the ones pictured in the link below are much more stark and you need not go that far. You then may be able to just tone down the color you have to get the color you want.
Here is a link that might be useful: Color washing
- Posted by bronwynsmom (My Page) on Mon, Nov 26, 12 at 9:07
| Always most informative, funcolors. So can you answer this one for me? |
| Yellow can be very transparent. As transparent as a cranberry, blue-red. Transparent colors require the proper undercoat and perhaps an extra coat beyond the typical two. Price point is very important when choosing certain colors like transparent yellows and reds. Cheaper paints, even with the proper color undercoat, can take anywhere from 3 to as many as 7 coats. And no guarantee that even after 6 or 7 it's going to look "right". Definitely want to purchase upper tier paints when choosing certain colors. Because it will save you tons of time and a chunk of money in the long run. The newer paint brews, like Aura from Benjamin Moore, do indeed offer high opacity, more efficient coverage even with the transparent colors. |
- Posted by bronwynsmom (My Page) on Mon, Nov 26, 12 at 20:12
| Great. Thank you, funcolors. I've also found reds to be a bear to get right, and loved the way the Aura colors perform. We did our den in an Aura terra cotta, and it covered pale yellow-beige in one application, with overlapping roller tracks. So I would second the recommendation that you use high-quality paint. You will end up using much less, and in a large space you often spend no more than you'd have to for cheaper paint and more coats...with a far better result, and less of the painter's time to pay for. |
