JOIN NOW LOG IN
So I made these curtains...
Posted by angelaintx (My Page) on
Fri, Nov 20, 09 at 13:07
....and I need to know what is "off" about them. My husband says that they are mounted too high, but I don't agree. My sister, who is an interior decorator, told me to accordian fold them and iron them so that they have some pleats in them. She said they need more dimension and that this will help. Anything else? I really love them and want them to work. I also don't like that when I pull them back, I can see a white part of the blinds. I may need to do something about that too. I still need to make the second panel.
Oh, and they don't touch the ground all the way because we have scorpions on this part of TX, and they like to crawl up curtains...ick.
RE: So I made these curtains...
IMHO they are too short, by an inch or so. I don't think they are hung too high though. If you cannot let down the hem, you might use rings at the top.
They also look not quite full enough. What is your fullness ratio? I was taught that panels should always be at least 2x the width being covered (ex. 42" window = 84" panel) or a width and a half of fabric (ex. 54" fabric = 81" panel) whichever is greater.
I think drapery weights in the bottom might help them hang better too.
I know it's $$$, but is there any chance you'd go over to stained wood blinds or woven wood?? Perhaps use those somewhere else or sell them? It's just the starkness of the white that jumps out but I'm not going to tell you to go out and replace all your blinds if there's a lot of windows in here. But if there were just several? You might consider that....the room is earthy with mostly jeweltones and a more masculine feel that the wood stain would complement. I like the fabrics together and the trim is a nice touch.
Most men ALWAYS think drapes should be hung on the window casing from what I've seen...lol. Pay no attention. :)
Doesn't matter that they don't touch the floor since they'll be swooped back...that looks nice.
Ick
oh my! just re-read and noticed the comment about scorpions! ICK is right!
They're very pretty. What caught my eye is I don't think they're full enough. I think fullness adds richness.
I can understand why you have them off the floor a bit if scorpions are a problem!
If you're not loving seeing the white blinds I second changing them to woven wood if it's in the budget. Seeing your white blinds don't bother me though since your trim and door are white.
I don't think they're mounted too high, and I probably would've raised them higher. My DH said the same thing at first when I raised our LR curtains to the bottom of the crown moulding. :) I like the fabric so much though that I probably wouldn't redo or replace the one you have if it doesn't bother you. It's still higher than the window and door.
2RE: So I made these curtains...
I agree on the fullness too...2 or 2 l/2x is the norm. That might be what's bugging you.
They don't look full enough and are also too short, looking much better when pulled back because they drape. The amount of space between the wall openings and rod doesn't feel right to me; they look a bit high. Maybe about 6" ? is the guideline above the door/trim, if you're not taking them to the ceiling. A quick google should turn up the recommended spacing for that.
Will you be keeping them tied back? If so, you can pull some of the right edge of fabric up from the tieback to give some more slack in the fabric and you should be able to pull the top portion closer to the fireplace. You might use some tape or something on the back of the fabric to attach it to the header of the blinds or to the fireplace. That should keep the top of the blinds from showing. Worth a try. The fabric is beautiful and I like the top being in a coordinating fabric to give additional interest. Like the others, I believe they could be fuller, but if you keep them tied back it's not as noticeable. Also, if you put them on clips I don't think they need as much fullness as when gathered on a rod. Regardless they are pretty and you probably couldn't find anything ready made that's as nice.
She needs them to be a little on the short side. I would say they need a little more fullness. If it was fuller and a little lower you might not be able to see where red wall and white blind meet. That's the part that I don't like.
We can pick out minor things in the drapery panels that we may want to change, but I think it is the odd arrangement of the room that is causing the problem.
Left to right I see a patio door, a bit of space, and then two windows butting a fireplace. The window-fireplace-window arrangement is odd enough, but when you add drapery panels and hide the windows, it looks like you are trying to fit drapery panels on either side of the fireplace.
It looks less strange when the drape is pulled back.
Question about the color: my screen is showing gold drapes on a raspberry colored wall. Is that what's really there?
I think they would look better slightly lowered. The scorpion problem can't be too much of a concern if you keep you baby's carrier on the floor.
I would also add some fringe trim to the side of the curtain to help make them seem a little more fuller.
I agree with the others that more fullness is needed and if they're in your budget, wood blinds would look much better.
I don't think the issue is with the height you have them but in doing that, the goal is to dool the eye. But since you can see the wall above the window and the blind-header, it's not working. I think you need to have that top line of the panel hide all that like in the pic I have below.
I think I'd scratch the drape idea and go with some pretty roman shades.
First of all, nice work on the curtains. They are really pretty.
I think that the light stone of the fireplace and the white blinds are a big light mass that make the curtains really jump out. Some wood or woven wood blinds would look really nice. I agree with those above that the curtains might need to be a little fuller. They do look best when they are swagged back. Would it be possible to divide the panel in two, and swag back both sides? It might look a little more balanced.
They must be just right, they match the kitty!!!! They look fine to me..you did a good job!
Where are you in Texas...I'm right in the Heart 'O Texas!
I think they are very pretty but if you aren't going to pull them back they need to be fuller and slightly longer. I used to have scorpions (I'm in Texas, too) and never heard of them crawling up drapes.
Well, you did a great job! I think that the others are right in that maybe they just aren't quite full enough. The other thing is though that most of the time I see drapery like this, the solid portion is typically on the bottom. I'm not saying it's right or wrong, but if you're more used to seeing them that way and these are the opposite, it could just be the change from what you're used to seeing. I love them though, like I said, I think you did a great job, want to come do mine? :c)
Angela, I like your mix of fabrics. I can't see the colors in the main fabric, but I'm sure it matches the wallcolor better than the picture tells. Details get lost if you're not doing a close-up.
Here's my critique, and I know you don't do this for a living, I do, so certainly not meant as being mean, but I will tell you what I'm seeing.
1. Rod is too skinny. That bulky fireplace needs panels that are hanging from or shirred on a bigger rod. A 1 3/8 inch would be OK, I don't think your's is that big, or I can't tell.
2. Sometimes painted wall space is fine between drapes and window, we just hung panels like that, but the color contrast is too much. As said above, if you're going to fake that the window is higher, then the curtain would have to be about twice as full and really hang down and cover the wall and top of the blind. Otherwise, hanging a roman or woven wood shade as an outside mount and the same height as the rod works.
3. I like a return on most all drapes. That means when you walk beside the panel, you can't see behind it. It's hard to do a return with a rod pocket, easier with pinch pleats.
4. Are they lined? If not that would add some heft and a little more bulk which they need. Probably don't want to sew another width or half width of fabric to these, so lining would really help, and even interline them with flannel for more fullness. Sometimes it helps when you can't get the total width you need.
5. I know you probably need to keep the white blinds, but I still vote for woven woods either alone or with the panels.
I just finished installing panels next to a fireplace in a formal living room. The room is very different from yours as is the fabric. I'll try to get it posted to my blog in a few more days.
Here is a link that might be useful: Give me a couple of days to post today's install!
dont laugh, Just an idea but would you consider spray painting the blinds? that may not even be feasible, but I think if they were done with care and good spray paint or a spray gun, they might be ok? At least you could tone down the white.
Wow, thank you so much for all of the responses! I kept looking at them yesterday and they just seemed off, and it's the fullness. It's a 36 inch window with 55 inch curtains. It seems more like a sheet to me than panels. I think I am just going to get some panels and hang those. Love the fabric but really don't have the time to add more to the panels and then make another one.
Dillydally- Actually, scorpions tend to stick to baseboards when they come in. Very rarely do I see one in the middle of the room. My daughter has 95 inch panels that touch the floor in her room, and I have found scorpions on the panels more than once.
I actually wondered that too....using that new spray paint~
I really like the drapes pulled back~
GORGEOUS fireplace! And the fabric is pretty too:)
I think you need to make 3 more panels, not 1. Then hang 2 panels on each rod. This would definitely solve the fullness problem. It would also bring some definition to the FP, some separation between the blinds and the stone.
To bring them lower w/o moving the rod, you could try some of those ring/clips. I understand about the scorpions--but I just can't see having my drapes that short. If they get in your house, they are going to be "somewhere" so they may as well be on the drapes, not in the baby stuff. Anyway, won't they hide in those pretty baskets you have there now??
When my parents lived in Houston, they had a monthly plan with a pest company because of the scorpions. Have you tried that?
I was just going to say exactly what tomorrow said. You don't usually see panels covering the whole window. I would also like to see a panel on each side.
Laurie
I agree with tomorrow too on two points. The curtains arent full enough and the simplest solution is to make more of them and have two panels per window rather than scrapping them and starting again.
I also agree with this:
" If they get in your house, they are going to be "somewhere" so they may as well be on the drapes, not in the baby stuff. "
If you get scorpions in the house then they are going to be hiding somewhere, better to be on the curtains where you know where to look for them instead of some unknown hiding place. I grew up in an area with scorpions and they do seem to like attaching themselves to fabric but it's better than having them crawling and hiding in other places where you might not expect them so I would also lower the curtains and get into a habit of checking them for scorpions if you think they are going to be in there.
I highly recommend the attached blog post for anyone who would like to learn some dos and don'ts for window treatments. While most of the pictures depict rooms that have been styled by designers, the principles can be applied to everyday living. I love the volume of pictures and the examples used to illustrate the points.
Enjoy!
Ellen
Nouveau Stitch
Here is a link that might be useful: Cote de Texas...Top Ten/Window Treatments
Interesting, the post is still here but the link has whooping cough.
RRE: So I made these curtains...
But CDT works. Just can't link your own!
I looked up nouveau stitch and went over, a great blog, some yahoo ads you can ignore; very valuable info. She also provides an extensive list of sewing blogs/links.
ellen, I love your shopping bag line-up decor, it makes me regret not having saved mine; I also adore your silk diamond drapes with the thin black band.
I bookmarked your blog.
Hmmm. Not sure why the link doesn't work. I attached it below.
Thanks for the compliments! I love sewing ~~ especially window treatments!
Ellen
Here is a link that might be useful: Nouveau Stitch
a very nice room, i must say. and yes, i know all too well about those scorpion issues...eek. so no prob on the length (form and function :) )...
everyone has already put in some great ideas, to be sure. i concur. but had to tell you how drawn i am to your choice of fabric and trim combo...superb!
I'm confused as to why the curtain on the left is so high and the one on the right is lower. That is what jumps out at me... it looks odd. Also fuller, better:)
Great job sewing!!
I'm kind of with kjmama - what stands out to me is the fact that the window on the left has a full curtain with a higher rod, and the window on the right appears to have just a valance with a rod hung lower. Correct me if I'm wrong?? To me that is the issue.
I think the curtain you have made on the left is nice - I don't think it needs to be longer or fuller - I just think whatever is on the right needs to match. PS - good job sewing your curtains! I have made curtains (not as elaborate as yours) and I know its a lot of work!
guys - I'm pretty sure she's making one to go on the right side also. She just wanted to make sure she's on the right track before she does that.
Laurie
