size of chairs in relation to dining table plus rug question
functionfirst (
Mon, Nov 19, 12 at 12:55
| I have a 66" square glass dining table held up by a square base--no legs at corners. How many chairs can I fit around this table which will usually seat adults who are relatively average in size--not overweight but not skinny. Second question is what size area rug should I put under it, i.e. how much space should I allow to pull out the chairs? There must be a rule of thumb but I don't know it. Thanks very much. |
RE: size of chairs in relation to dining table plus rug question
| Add 12" to each of the four sides, so a minimum of 9.5 feet square, but 10'x10' would be even better. General rule for table top space is 24" per diner. On a square table, you also have to account for overlap, so your table should fit eight comfortably. |
| If that is as big as I think, you should be able to get 2 chairs on each side. 8 total if you need that many. "rule of thumb" is that the chair is still on the rug when you have the chair pulled out and in use. |
Edited answer: For the rug, add 12" to each of the four sides, so a minimum of 9.5 feet square, but 10'x10' would be even better. General rule for table top space is 24" per diner. On a square table, you also have to account for overlap, so your table should fit eight comfortably. |
| Thanks very much!! I see that some companies do make 10x10 area rugs, so that's great news. |
| I recently got a square dining table and was considering round rugs as well as square ones. I think I've decided not to use a rug at all. |
