- All Products
- Hall
- Ceiling Lighting
- Ceiling Fans
- Fixture Finish: White
White Ceiling Fans
- Bulb Shape: Integrated
- Dimable: Yes
- Design: 3 Blade Propellar
- Amps: 0.36
- Color Temperature: 3000
- Lumens: 1500
- CRI: 90
- Canopy Included: Yes
- Shade Included: Yes
- Sloped Ceiling Adaptable: Yes
- Canopy Diameter: 6.00
- Rod Length(s): 4.50
- Dimable: Yes
- Assembly Required: Yes
- Dimable: Yes
This Matte White 44 inch ceiling fan from the Sola collection which can be used in wet locations, features integrated LED lighting and flush mount installation. The globe inspired motor housing shape brings delightful style to any space. A metal fixture cap is included for non light use installations.
- Voltage 120
- Number of Bulbs 1
- Bulb Type LED
- Wattage 17W
- Bulbs are included
Motor & Fan: With the modern black or white finish, the fan provides 6 fan speeds and delivers powerful air movement with quite a performance
Remote Control: You can keep the fan works with the remote
Warranty: 1-year unlimited warranty, friendly customer service, 100% SATISFACTION GUARANTEED
- Number of blades: 3
- Number of speed settings: 6
- Remote control included: Yes
- Battery operated: Yes
- Batteries included: No
- Motor type: DC
- Mounting: Down rod mounted
- Number of rods included: 1
- Rod lengths: 4.5 in
- Overall Size: D: 56 in*H:10.6in
- Canopy Size: D 5.8 in
- Weight: 17.52 lbs
- Maximum airflow speed: 4611 CFM
- Reverse airflow: Yes
- Wall switch operated: No
- Slanted ceiling compatible: Yes
- Maximum angle: 15 degree
- UL listed: Yes
- UL rating: Dry
- Wipe clean with a damp cloth
- Note: Item must be hardwired and professional installation is recommended
Features
- Model F518L-WH
- White Finish with White Blades
- Etched White Glass
- 3-Concave Blades 44" Sweep
- 14 Degree Blade Pitch
- Flush Mount - Ideal for Low Ceilings
- Cap for Non-Light Use (Included)
- Integrated Dimmable LED Light
- Remote Control System
- Factory Authorized Seller; Full Factory Warranty
Control Specifications
- Model RCS212
- Includes 1 Hand Held Remote Control and Wall Holster
- 3-Speed Fan Control in Forward and Reverse
- Full Range Light Dimmer
- Operates at Distance of 20-40' Depending on Construction of the Room
- 12 Volt Battery Included
Light Specifications
- Uses 15 Watt LED (Included)
- 537 Lumens
- 3000K
- CRI 83
- Rated 30,000 Hours of Continuous Use
- Performance
- RPM (High/Low): 180/80
- Airflow: 4,071 CFM
- Electricity Used: 43.7 Watts
- Airflow Efficiency: 93.16 CFM/Watts
Ceiling fan with remote: With the remote control, the fan provides 3 fan speeds (Low, Medium, High) and delivers powerful air movement with quite a performance.
Ceiling fan with downrod-Mount: Adjustable hanging height, 4 &10 inch downrod included, you can choose the length according to your needs.
Modern Ceiling Fan: It is a better combination of a ceiling fan and light.
Warranty:1-year unlimited warranty, friendly customer service, 100% SATISFACTION GUARANTEED
Features:
- Design: Standard
- Mounting: Downrod-Mount
- Downrod Length: 4 inches and 10 inches(2 pcs)
- Style: Modern & Contemporary
- Indoor/Outdoor: Indoor
- Number of Lights: 3
- Bulb Base: E26
- Bulb Included: No
- Number of Blades: 3
- Blade Span: 42 inches
- UL Rating: Dry
- Maximum angle: 15°
- Overall Size: D: 42 ”*H:18.62”
- Canopy Size: D 5.9”
- Weight: 22 lbs
- Rated Voltage: 110-120 V
- Motor: 153x12mm pure copper motor
- Features: Remote Control
- Remote Included: Yes
- Suggested Room Size: 90-225 sq.ft
Product Features:
- Finish: White
- Fan Type: Hugger
- Blade Span: 52"
- Number of Blades: 5
- Height: 8.75"
- Speeds: 3
- Location Rating: Dry Location
- Fully covered under Minka-Aire warranty
- Color: Cream White
- Material: Metal, Plastic
- Voltage: 110 -120 Volts
- Light source type: LED
- Light Kit Included: Yes
- Light Wattage: 30 W
- Dimmable Light: Yes
- Dimmer Switch: NO
- Reversible Blades: Yes
- Number of Blades: 7
- Speed: 6
- Control: Remote Control Included /Smart APP
- Remote Batteries included: Yes
- Room Size: Small & Medium rooms (up to 12 X 14)
- UL Listed for core parts
- ETL Listed for ceiling fan
- Hardwired, Assembly Required
- WARRANTY: Lifetime warranty on motor; One-year warranty on all other parts
- Please feel free to contact us via our email if there is any questions, and we will reply in 24hrs.
- Reversible motor allows you to change the direction of your fan from downdraft mode during the summer which helps cool the room to updraft mode during the winter to help circulate trapped warm air near the ceiling.
- Reversible, 3-speed WhisperWind motor delivers ultra-powerful air movement with whisper-quiet performance so you get the cooling power you want without the noise you don�t
- Installer's Choice three position mounting system allows for standard, low or angled mounting
- Damp rated for use as an indoor or outdoor ceiling fan in spaces exposed to moisture and humidity such as porches, patios, sunrooms, and bathrooms
- Features stainless steel hardware to resist rust
- 13 degree blade pitch optimized to ensure ideal air movement and peak performance
- 3 Fresh White / Light Stripe reversible blades included
- Includes 5'' and 3'' downrods to ensure proper distance from the ceiling and optimize air movement at your preferred blade height
- Includes pull chains for quick and easy on/off and speed adjustments
- Limited Lifetime Motor Warranty is backed by the only company with over 130 years in the fan business
Features
- Model F753-WHF
- Flat White Finish with Flat White Blades
- 3 Blades 54" Sweep
- Hand Held Remote Control for Wireless Operation
- Indoor or Outdoor Use*
- Includes 6" Downrod
- Factory Authorized Seller; Full Factory Lifetime Warranty
- Model RCS213
- Can Be Used with WCS223 Wall Mount AireControl�
- Performance
- RPM (High/Low): 150/71
- Airflow: 5682 CFM
- Electricity Used: 47 Watts
- Airflow Efficiency: 121 CFM/Watts
*All Finishes Can Be Used Outdoors EXCEPT Polished Nickel
- Product Style : Contemporary
- Blade Finish : Flat White
- Length : 52 Inch
- Height : 9.25 Inch
- Width : 52 Inch
- Downrod Width : 0.75 Inch
- Fan size : 52 Inch
- Weight : 10.36 lbs
- AMPS : 0.44
- CFM : 5816
- Airflow Efficiency : 113.37
- Wattage :51.3
- RPM : 212
- Certifications: ETL
- Energy Star : Yes
- Blade Pitch : 22
- Shipped Via : Ground
- Bulb Included: No
- Switch Type : Hardwired
- Country of Manufacture: China
Features:
- Set includes: One (1) ceiling fan with remote control
- Material: Metal (fan housing) and ABS (blades)
- Finish: Antique White
- Ceiling fan dimensions: 14.8 inches high x 52 inches wide x 52 inches deep
- Blade dimensions: 20.35-inch
- Winter/Summer mode manual switch
- Motor size: D153 X 25mm
- Airflow(CFM): 5656
- Number of speed: 6
- Power Consumption Average(wattage): 42W
- Motor Wattage: 42W
- Include 1 x GX53 18W 3000K bulb 1700 Lumens, 3 step dimming
- Socket: GX53
- RPM H/M/L (motor speed): 169/128/75
- Fan Watts when used at high speed: 42W
- Voltage:120Vac, 60Hz
- Dimable: 3 step dimming
- This product will ship to you in one (1) box.
- Accessories pictured are NOT included.
- Assembly required.
- Low Profile housing is specially designed to fit flush to the ceiling and is ideal for use in rooms with low ceilings
- Rated for indoor spaces only
- 5 Fresh White / Natural Wood reversible blades included
- Includes pull chains for quick and easy on/off and speed adjustmentsIncludes 2 14W long-lasting CFL bulbs
- Includes Integrated light kit with Painted Cased White glass
- Includes 2 14W long-lasting CFL bulbs
- 4 Blonde Oak / Fresh White reversible blades included
- Includes 3'' and 2'' downrods to ensure proper distance from the ceiling and optimize air movement at your preferred blade height
- Includes Handheld Remote for easy speed and lighting adjustment from anywhere in the room
- LED light kit for lower energy consumption, brighter light output and a longer lifespan than traditional bulbsIncludes 2 9W energy-efficient, dimmable LED bulbs to give you control of the ambiance in your space
- Includes Handheld Remote for easy speed and lighting adjustment from anywhere in the roomLED light kit for lower energy consumption, brighter light output and a longer lifespan than traditional bulbs
- Includes 2 9W energy-efficient, dimmable LED bulbs to give you control of the ambiance in your space
- Bulb Included: No
- Style: Transitional
- Blade Finish: Flat White
- Rpm: 130
- Amps: 0.62
- Watts: 51.98
- Hight CFM: 9092
- Dimmable: No
- Material: Metal,Alum,Stainless Steel
- Bulb Included: Yes
- Shade: Etched Lens
- Glass: Frosted
- Light Kit INocluded: Yes
- Blade Finish: Bone White
- Rpm: 196
- Amps: 0.57
- Watts: 67.28
- Hight CFM: 5450
- Color Temp: 3000
- Cri: 95
- Initial Lumens: 1201.6
- Delivered Lumens: 896.3
- Rated Life Hours: 30000
- Dimmable: Yes
- Material: Plywood Construction,Zinc,Aluminum
- 5 Fresh White / Light Oak reversible blades included
- Includes pull chains for quick and easy on/off and speed adjustmentsIncludes 2 13W long-lasting CFL bulbs
- Includes Bowl light kit with Clear Frosted glass
- Includes 2 13W long-lasting CFL bulbs
Features
- Model F787-WHF
- 3 Blades 52" Sweep
- 14 Blade Pitch
- DC 123 x 30mm Motor
- Indoor and Outdoor Use
- Custom 15W LED Light Kit K9787L Available (Sold Separately)
- Model RC400
- Six Speed Fan Control in Forward and Reverse
- On/Off Plus Full Range Light Dimmer
- Includes One Hand Held Remote Control, Wall Holster
- Operates at Distance of 23' Depending on Construction of Room
- Performance
- RPM (High/Low): 191/148
- Airflow: 7051 CFM
- Electricity Used: 33.1 Watts
- Airflow Efficiency: 213 CFM/Watts
- Reversible, 4-speed Direct Drive� motor provides unparalleled power, silent performance, and reliability over decades of daily use
- 16 degree blade pitch optimized to ensure ideal air movement and peak performance
- 3 Fresh White blades included
- Includes 4'' and 2'' downrods to ensure proper distance from the ceiling and optimize air movement at your preferred blade height
- LED light kit for lower energy consumption, brighter light output and a longer lifespan than traditional bulbsIncludes 1 18W energy-efficient, dimmable LED bulbs to give you control of the ambiance in your space
- Includes 1 18W energy-efficient, dimmable LED bulbs to give you control of the ambiance in your space
Available in Gold, White, Nickel, Coffee, Pink and Blue.
High-Quality Ceiling Fan Chandelier with Bladeless Technology - Perfect for Living Rooms, Bedrooms, Kitchens and Office. When turned on, the outer casing of the fixture spins at one of six speeds projecting a smooth, natural airflow that significantly lowers the room's temperature. The LED light can be controlled separately from the spinning function making for a beautiful lighting pendant when not in motion.
Revolutionary Technology - The only 100% Bladeless ceiling fan online, this fan quietly circulates air with only the outer casing of the fan spinning. Safer, quieter and beautiful in any setting!
6 Speed Remote Control with Reverse Option - You can switch between the different modes, wind speeds and timing settings with the push of a button. Includes High, Medium & Low wind speeds and 1-hour, 2-hour, 4-hour & 8-hour timing settings.
3 Color Integrated LED Light - 3 different colors of soft light change between warm, white and neutral by remote control.
Quality Warranty - We offer a 1-year quality warranty that includes free replacements. Also, we provide an installation video for this fan with purchase. If you have any questions about the fan or installation, please contact us directly. We are here to ensure that you are satisfied with your purchase!
- Specs
- Brand:Todays Fans
- Height: 11.4" (flushmount) / 12.7" (with 6" downrod) / 17.7" with (10" downrod)
- Width/Dia.:23"
- Weight:19 pounds
- Downrods Included:1x 6" and 1x 10"
- Location Rating:Indoor
- Watts:50
- Motor Speeds:6
- Control Type:Remote Control
- Material:Eco-Friendly ABS + Iron
- Bulb Type:LED
- Light Colors:Warm, White and Neutral
- Warranty:1 Year
Features
- Model F833-WH
- White Finish
- 22" Blade Pitch
- 2-Wire Installation Wall Control
- Converts to Electronic Control System
- Four Speed Fan Control
- Performance
- RPM (High/Low): 201-104
- Airflow: 6,304 CFM
- Electricity Used: 55 Watts
- Airflow Efficiency: 114.62 CFM/Watts
Features
- Model F843-WHF
- Flat White Finish
- Variable Blade Pitch
- Includes 6" Downrods
- Hand Held Wireless Remote Control System
- Model RCS213
- Three Speed Fan Control
- Can be Used in Conjuction with WCS223 Wall AireControl
- Performance
- RPM (High/Low): 153-61
- Airflow: 6,580 CFM
- Electricity Used: 66.4 Watts
- Airflow Efficiency: 99 CFM/Watts
Product Features:
- Finish: White
- Fan Type: Hugger
- Blade Span: 42"
- Height: 8.5"
- Speeds: 3
Features
- Model F753L-WHF
- Model RCS213
- Uses 17 Watt LED (Included)
- 1550 Lumens
- 3000K
- 3 Year Warranty on Light
- Performance
- Airflow: 5682 CFM
Features
- Model F1000-WH
- 5 Blades 52" Sweep
- 12 Degree Blade Pitch
- 3 Speeds and Full Range Light Dimmer
- Indoor Use Only
- Model RCS213
- 1100 Lumens
- 2700K
- CRI 80
- 3 Year Warranty
- Replacement LED Accessory (Part #6F1000LK01)
- Performance
- RPM (High/Low): 175/63
- Airflow: 5295 CFM
- Electricity Used: 64 Watts
- Airflow Efficiency: 77 CFM/Watts
- 56-inch indoor ceiling fan with three blades
- 3 aerodynamic curved metal blades
- 172-by-12-millimeter cold-rolled steel motor with single capacitor for powerful and quiet air circulation
- Five fan speed wall control for customized comfort.
Finish Details
- White steel blades
- Versatile white finish.
- Ideal for rooms up to 360 square feet (18 by 20 feet)
- Must be hung at least 10 feet above the floor
- Not recommended for use in household applications
- Includes 1/2-inch by 12-inch down rod, 54-inch lead wire, five-speed wall control unit, and ball-hanger installation system.
- 5 Fresh White / Drifted Oak reversible blades included
- LED light kit for lower energy consumption, brighter light output and a longer lifespan than traditional bulbsIncludes 3 6.5W energy-efficient, dimmable LED bulbs to give you control of the ambiance in your space
- Includes 3 Light light kit with Clear glass
- Includes pull chains for quick and easy on/off and speed adjustmentsLED light kit for lower energy consumption, brighter light output and a longer lifespan than traditional bulbs
- Includes 3 6.5W energy-efficient, dimmable LED bulbs to give you control of the ambiance in your space
Transform your home into a sanctuary of modern comfort with your cutting-edge LUMIO bladeless, small ceiling fan with a light. Say goodbye to the outdated fans of the past and embrace a world where style meets innovation. Your Todays Fans outdoor or indoor ceiling fan with lights and a remote is not just a cooling device; it's an elegant statement piece that beautifies your space. It is designed to function seamlessly in any home or size space.
Efficient and Adjustable
Delight in the customizable ambiance created by the 3 light temperatures, dimming options, 6 wind speeds, and auto-adjust features. Whether you're curling up with a book or hosting friends in the living room, your low-profile fandelier ceiling fan with a light ensures your space is always cooled and illuminated to your liking. The natural wind feature adds an additional layer of atmospheric comfort, mimicking the gentle, refreshing breeze of the great outdoors. Compact yet powerful, this remote ceiling fan with lights is a versatile fit for any room and can be connected via Wi-Fi to Alexa, the Smart Life phone app, or Google Home.
Effortless Install, Modern Appeal
- We provide everything you need to get your modern ceiling fan with a light remote set up in no time:
- – Hanger bracket for down rod installation
- – Canopy
- – 4 in. and 8 in. downrods
- – Led light
- – Hanger bracket for flush mount installation
- – Fan body
- – Canopy cover ring
- – Screws
- – Fan bracket for flush mount installation
- – Light cover
- – Remote
- – Manual
Sleek Style – Create a cool, attractively lit space without the clunky blades of a fan. Your 28” Todays Fans ceiling fan with LED light delivers safe, innovative air circulation alongside elegant design.
Design That Shines – This feature-packed ceiling fan with lights and remote control cools and sets the mood with a night light, 6 speeds, temperature sensors, a timer, wind mode, 3 light tones, and more.
Smart Control – Comfort has never been easier. The LUMIO Wi-Fi chandelier ceiling fan with light blends into your smart home setup, allowing you to adjust lighting and wind speed with a phone or Alexa.
Effortless Setup – Elevate any space, including narrow hallways or bathrooms, when you hang this low-profile ceiling fan with lights and flush mount or downrod install options.
A Beautiful Breeze – Since 2014, we’ve crafted fans that cater to your desired look and function. Whether as a bedroom ceiling fan with light, living room fixture, or porch fan, LUMIO offers the ideal solution.
- Specs
- Brand: Todays Fans
- Total Height: 9" (flushmount) / 13.7" (with 4" downrod) / 17.7" with (8" downrod)
- Width/Dia.: 28"
- Weight: 33 pounds
- Downrod Included: 1x 4" and 1x 8"
- Location Rating: Indoor
- Fan Wattage: 60
- Light Wattage: Main Light: 36W + Night Light: 15W
- Motor Speeds: 6
- Control Type: Remote Control
- Material: Eco-Friendly ABS + Iron
- Bulb Type: LED
- Dimmable: Yes
- Light Colors: Warm, White and Neutral
- Lumens: Main Light: 2400
- Warranty: 1 Year
- 3-blade ceiling fan
- Energy efficient
- 6 speeds
- DC motor
- Weight: 14 pounds
- Voltage: 110/220
- Not recommended for ocean-front applications
- Airflow: 3940 cubic feet per minute
- Airflow efficiency: 122 cubic feet per minute per watt
- Electricity use: 32.3 watts (excludes lights)
- Color: Gloss white and walnut tone
- Materials: Cast aluminum, polycarbonate and heavy-stamped steel
- Dimensions: W 56" x D 56" x H 9"
- Motor Type: DC
- Fan Wattage at High Speed: 33
- CFM Low: 1633
- Average Airflow Efficiency: 164
- Noise Level: Silent
- UL Listed: Dry
- Blade Finish: Antique White
- Moto Sizer: 188x15
- RPM: 169/106/51
- Fan Watts: 80/33/9
- Fan Amps: .69/.44/.23
- Control: Hi/Med/Lo/Off
- Fan Sweep: 52 in.
- ILLUMINATION
- Bulb(s) Included?: No
- STYLE
- Finish: Studio White
- Collection: Empress
- Material: Mixed
- Blade Count: 5
- Blade Finish: Studio White , Studio White
- Blade Pitch: 14"
- Motor RPM: 154
- Motor Size: 188x15mm
- Fan amps: .65/.44/.23
- Fan watts: 75/33/9
- Fan RPM: 154/102/57
- ADDITIONAL INFO
- Energy Star
- Weight: 23 lbs.
White ceiling fans can be very versatile pieces, ranging from modern to vintage and every look in between, all while serving one very important purpose: keeping the air flowing. You can bring as little or as much attention to your new fan as you want — you just have to find the right fixture for your desired style. Consider the following when shopping for a new white ceiling fan to ensure you get the most bang for your buck.
Make a Bold Statement
Although white may seem like a boring color, it can definitely pack a punch when it comes to style. The easiest way to make any white ceiling fan stand out is by pairing it with a non-white ceiling. Think wood or an accent color, like blue or gray. Any design against a colored palette will be sure to catch everyone’s eye, whether it’s something wild or subtle. To make a modern statement, look for sleek, retro shapes with clean lines and minimal detailing. For a more traditional statement, find a white fan with more intentional detailing, like carved fan blades. You can go vintage or farmhouse by using different whites that aren’t necessarily stark and bright, such as cream, off-white or distressed finishes. These will feel softer and can actually warm up your space. If elegant fixtures are your thing, but you need the functionality of a fan, look for a white chandelier ceiling fan that can do double duty. This would be ideal for a dining/living space.
Stick with Strictly Functional
Alternatively, a white ceiling fan can be a great option if you want something subtle that blends and doesn’t draw any extra attention. Since most homes feature white ceilings, a fan in a similar hue to your paint color will make for the most seamless look and feel. You can also opt for a subtle, low-profile design. These are known as ceiling huggers and make for an unobstructed view. Look for flush-mount styles with fewer blades and limited detailing. A white ceiling fan with a light will help minimize the amount of fixtures on your ceiling to keep things visually uncluttered.
