Software for sketching window elevations
Posted by mtnrdredux (My Page) on
Sun, Oct 7, 12 at 11:15
What's the best thing to use to play around with exterior fenestration layout? Skecthup? Or is there somthing specific to windows?
thanks in advance
RE: Software for sketching window elevations
Sketch up is fairly easy to pick up and it's amazing how quickly you can draw a house/add windows, doors etc. Take a few of the online tutorials and you should be able to do what you want, especially if you have general house dimensions. Best, oldbat2be
Yes, thanks, I've been using Sketchup but they don't have the exact windows I want.
OK - just double-checking that you've already tried drawing it yourself, already in Sketchup, using the dimensions?
I also have Chief Designer's Architect Plus. You can download various Library Catalogs (i.e., tile, countertops, flooring, roofs, etc).
I'm on version 9 (a little out of date) but I just checked and there are no window libraries for my version but for newer versions (Chief Architect Premier/Interiors, Home Designer Pro/Architectural/Suite) there are libraries for Marvin, Integrity and Therma-True. Best of luck and very much enjoy reading about your projects and watching your progress, oldbat2be
Oldbat2be,
I am a neophyte at Sketchup. I used it for my little stone house, and now I am playing with it as I ponder what we might do with the beachhouse we are looking at.
For windows and such, I import them as components. I just can't find the windows Id like to use, and it changes the look so much! I can't imagine drawing the window myself, but maybe I should try it.
Not sure if I should try the product you are talking about; assume it is not free!
tia
I think we paid ~150, no not free but with all your
projects... :)
There may be a tutorial on sketchup for drawing windows, worth checking. I am a neophyte too but found it amazingly good with just using dimensions, drawing rectangles and using the push/pull. Here was a backsplash I mocked up; I was really surprised at how realistic it looked. So, one big rectangle for the house and then a few smaller ones for the windows and doors...
Wow. OB2be, you are good!
I am having trouble getting dimensionality on things I draw. For example, I drew a porch roof. It is not a rectangle, it is a trapezoid. After I drew it, I tried to use the push pull to give it some dimensionality and opaqueness. DIdn't do anything .... ideas?
