6 panel or 2 panel arch top for door between garage and house?
Posted by janesylvia (My Page) on
Mon, Sep 24, 12 at 15:12
I am going to have my door between garage and house changed. I am hesitating on 6 panel or 2 panel, and woodgrain textured or smooth surface. I don't know which would look better.
Other doors would be changed later. But I need to buy this garage-to-house door first, since we just bought the house, and want to have all the locks re-keyed to the same key.
Fire-rated doors
Thank you very much.
RE: 6 panel or 2 panel arch top for door between garage and house
What style is your house? What style are your furnishings? Are you asking about a 6-panel straight top vs. a 2-panel arch top, or are both arch tops?
Whatever you choose should be the same as the others you will be installing later.
Go with a smooth texture for interior doors. unless you are going for a rustic look.
Chibimimi, thank you very much.
The house is ranch style built in the 70s in the bay area of CA. Furniture is contemporary style. I am hesitating on 6- panel straight top, or 2-panel arch top (with or without vertical grooves).
Unless you are planning a Mediterranean or French style overall, avoid the curved-top door. The six-panel doors are quite traditional, if that's your aim. But if you're hoping for a more contemporary/craftsman/casual look,what about a one- or two-panel straight-top door? These go with a wide range of styles.
Thank you very much, Chibimimi. The 2 panel arch top looks like this.
2 panel arch top door
If your style is contemporary, I would go with the door in the middle of the page you just linked-the Rockport model. It is the only one of those that is not traditional or French/mediterranean as Chibimimi mentioned. Seems that it would fit with a contemporary ranch.
