Large Spindles separate raised Dining Room from Kitchen, Help!
Posted by jsl225 (My Page) on
Sat, Sep 18, 10 at 13:19
I have a raised dining room off of the kitchen that is separated by
railing and very Large outdated Spindles. I am not sure if it is
structurally needed. I'd like to either remove them or perhaps
box them into columns? Has anyone seen done this? Any suggestions?
RE: Large Spindles separate raised Dining Room from Kitchen, Help
How about uploading a picture of the situation? A view from the kitchen side, and then a view from the dining room side back toward the kitchen.
In one of the HGTV shows where there was a difference in the levels, they took out a railing and instead installed a bank of shelving/seating, which gave storage on the low side and seating surface on the high side.
If your spindles are full height from floor to ceiling in the dining room, make sure they are not load bearing. Even then, the first option I mentioned COULD be used in the spots where the columns can be removed.
Someone here built a bar (island?) that had stools on the living room side and shelves on the kitchen side.
There is a header for the dining room and a
column at one point. I have base board heat
so that is on the outside of the raised room. There
isn't really any room to add a bar or etc since
it connects right into the kitchen and between
my living room & the family room on the opposite
side. I've added photobucket pictures, hopefully
it loads!
Here is a link that might be useful: Spindle Pictures
http://m1008.photobucket.com/albums/Jsl225/?pbauth=1_uLEBonVPfaLdh1h3YMYz2ZGMhFsjtIlQ9VSbwjeydSVDXxJWnHGAz0sMdXrNkFDrBxhztjTxCuxHjVdgt8yuZa9QrnuTSr0j09rVT/ackl2SEg5fI3BAKT1/WiVON31eNgkFhbXl%2BpchxC0qdL6laRkha4RojqLe
