Color Ideas Needed!
Posted by dellagiammusso (curlydella@yahoo.com) on
Wed, Aug 1, 12 at 11:56
I almost completed the interior of my garage.
I had my garage floor done with a beautiful black and silver flake epoxy over a light grey base tone on floor. The finish has a very high gloss top coat that looks stunning! . . It almost looks wet!
The walls were just painted a medium charcoal for the top half of the walls. The bottom half I had a PVC Material (taupe color) attached to the wall (easy to just hose down). Wall cabinets are white, and door at the moment, is a bright bright white color with black accents. I think I do want to keep the black accents.
I am trying to figure out:
(1) Should I mute the white a bit on the door color so not to be so stark and get them closer to the white in the cabinets orrrr maybe paint the door an extremely light grey color?
(2) The trim right now matches the wall which I'm NOT sure I like. I was thinking of doing the trim a very deep charcoal color (almost black but not quite) . . same color I actually used on the beam that runs across the garage ceiling. And maybe make the stairs the same color as the trim?
Need some suggestions.
I attached a picture to give you a visual.
RE: Color Ideas Needed!
I think I would paint the door the taupe PVC color.
what about the trim color and stair color?
