Keep at top - How to post pictures here!
Posted by nanny2a (My Page) on
Tue, Mar 6, 12 at 17:23
This thread will describe how to post pictures from a photohosting site, from a PDF file, or from some other location on the web.
First, though, where are your pictures? If they are on your computer only, you will need to upload them to somewhere on the web for the rest of us to see them. I upload pictures to PhotoBucket, but there are other photo-hosting sites available. For example: Picasa, Filckr, Webshots, Snapfish.
Open an account w/PhotoBucket or other photo hosting site.
Take a picture using a digital camera (or film camera, but get your pictures on a disk when they're developed & download them to your computer)
Resize your pictures so they're not too big, generally no more than 400x300 (or 300x400)
Resize keeping the same proportions so they don't get distorted...i.e., don't specify a specific size, use %-ages or similar
[You can also often resize pictures at your photohosting site, but it's faster to do it on your computer]
Upload your pictures to your photo account
Find the label that contains the HTML Code link to the picture and copy it
Paste it into the thread's "Message" box (< Ctrl >< V>)
Click the "Preview" button.
You will now see the picture.
RE: Keep at top - How to post pictures here!
this was sinking, so I am bringing it back up to the top.
The above method does not work with every single photo site. Some you have to get an http link, and then add this:
< img src=http .................... jpg >
NOTE there is no space between the < and the img or the jpg and the > I had to type it that way so it would show up. THERE IS A SPACE between the img and the src.
You have to add the < img src= and then put the http link right after the equal sign with no space. Then at the end of the link you put the > after the file extension type, which is jpg
Using this method you can post a photo of anything you find on the internet. Right click on any photo on any site and choose Properties. A window will pop up giving you the http location of the photo. Using the < img src=http......jpg > method that photo will appear in your post.
Bump...great info...
rebump
Bump again.........
I had trouble resizing photos on my computer. I would resize in photo bucket but sometimes it would not take and I spent too much time checking my preview message to make sure the size was not too large. Newbie mistake.
Then I noticed you can go into account settings, then click on the album settings tab. There is an upload option where you can choose what size the pictures will be. Problem solved.
bump
bump
I like using TinyPic.com for posting my pictures here. Set the picture size for message board, then copy and paste the HTML for Websites code into your post. Don't use the code for forums and message boards - it doesn't work for this forum. You can use it with or without an account.
Since is a picture is worth a thousand words, thought I would post this one..
Message above this shows it all.
Bump
Actually, my smugmug account does not post photos directly that way, which is why I posted the alternate instructions.
As an aside, does anyone know why photobucket photos are so frequently pulled from posts? I can understand if someone is linking to copyrighted photos, but occasionally the posters' own pictures are pulled. .
Bumpity bump
Kswl, I think the posted pictures get pulled because when the poster changes their photo location in their photobucket account, the link to the posting is lost. It has happened to me for that reason. People sometimes try to reorganize their account albums and then the links to the post are broken. So, after my error, my recommendation is to organize your albums according to projects, or what ever, before you start posting to this site. Then you wont be fiddling around with the location and thus loosing the links. For example I even have an album just for images that are holding other peoples images that didn't know how to post and I did it for them. I try to have all my settings set as private so that other images can't be viewed, only the ones posted. I notice some people even put a watermark on their own images, I think that is a good idea. I haven't done that yet but I plan to one of these days:)
Terri....I like tinypic too, thanks to you. Have you found a way to upload more than one photo at a time? I don't have or want to create an account. Thanks.
I think that you do need to have an account to post multiple pics at one time to Tinypic. I like having an account, because I can then post the same pic again, or just look for it for reference. I don't put anything on there that I don't mind if all the world sees.
Skimmed & didn't see it mentioned. There is also the Test Forum. Practice to your hearts content, that's what it's for. :)
If you delete photos from your account, they will no longer show up in a post also.
I find that the preset large setting is good for resizing photos. I wouldn't go smaller than medium because it's makes the picture harder for some to see. Also wouldn't go any bigger than the large.
Just another note, sometimes when previewing, after you resize and are ready to post, the photos still look HUGE in the preview but appear the correct size when viewed in the thread later. I don't know why this is but as long as you resize them, it should be ok. However, when previewing, if you copy the HTML code as shown above, that 'will' show up if you did it right.
Shee, it's because the pictures are stored in the cache on your computer in the larger size.
Nanny2a,
I wanted to respond to your other 'how to post a pic' thread w/o posting on it. Even threads that have no responses will begin to sink to the bottom so you eventually have to respond to it to bump it up.
Maybe you can check w/ the moderator to see if there is a way to permanently keep a 'How to post pics' thread at the top.
Nanny, your other thread is also incomplete. If you read Kswl's post on this thread you'll see that there are alternate methods for posting photos from other photo-hosting sites as well as from the entire internet.
just bumping
To keep pictures from getting too large, after the img src=" " add width="440" then the closing bracket. It will make sure the pics are posted at a reasonable size.
bump
bump
Bumping
bump!
A bump for this topic and a question:
Does anyone use snapfish for sharing pictures on this forum? If so, can you tell me how to do it please?
I have a photobucket account that I usually use but for some reason I cannot get logged in. Rather than open yet another account on another website I thought I would see if my existing snapfish account would work. I have the pictures loaded to snapfish already but I cannot get them to appear in my post on GW. There is a section to "share with a link" and this appears there:
http://www2.snapfish.com/snapfish/thumbnailshare/AlbumID=........../CO BRAND_NAME=snapfish/
Perhaps I just need help with the HTML code to use this link in my post.
TIA.
I've been using Flickr, and it's incredibly easy and fast. I'm a complete technodolt, I don't understand how to do half of what you all are talking about, and if I can do it...
Bump.
bumpity bump bump bump
terriks, are you dragging your teddy bear behind you down the stair...?
They've made it so easy now, just save your photo to your desktop then browse to pick it up there, if it needs editing, resizing etc. do all of that before you save it to your desktop. then if you choose to keep it make a new folder to drop it ibnto on your desktop.
bump
OK -- so I can't use my iPhoto? I need to transfer photos to another site first (photo bucket, etc)
Sometimes my iPhoto works - but I can only post one photo at a time. The only photos I seem to able to post are those taken from my iPhone and then transferred to my iPhoto. Those uploaded from my camera are too large, and I don't know how to resize them.
Why can't things be easy?
I have been using the (relatively) new browse feature here so I can upload from the files on my PC. However, I haven't figured out how to get more than one picture using the browse feature.
Thank you KSWL! It worked!
I upload a few photo's at one time, read my prior post here, it's easy here's photo's I combined using photoscape, then saved to my desktop, to browse and load here:
Example:
Bump TTT
Bump.....
BUMP
I've never knew how to post an internet found photo into a post. Hopefully this works.
This post was edited by debrak_2008 on Wed, Feb 13, 13 at 21:33
bump
BUMP
okeydokey.
Lumpy bumpy
Just a teeny bump
Bump
bump
bump
