JOIN NOW LOG IN
Please help me find pics of fireplace reno's
Posted by kew2006 (My Page) on
Mon, Feb 8, 10 at 13:06
There is a house my husband and I are thinking about buying. Problem is we really don't like the fireplace in the family room. It is a look you've seen before. Full wall of whitish colored brick, small, low firebox, no mantle at all. I know I've seen people transform those fireplaces/brick walls before but I can't seem to find them when I search. I'm certain this is something we should overlook and fix, but husband is not so convinced. Maybe if I could show him what other people have done he'd be able to see the possibilities. Can anyone point me in the right direction? Thanks!
RE: Please help me find pics of fireplace reno's
We have the same sort of situation (except ours bricks are regular color and have weirdly offset brick shelf and little Virgin Mary niche! Totally impossible to hang art, etc. Yuck.)
We've toyed around with several options, including painting the brick; veneering it with a hand-troweled painted plaster or modern concrete; knocking off the shelves and covering the brick with a chic cedar veneer, or just plain old drywall.
After living with it for a year and a half, and nearly completing major renovations in the adjacent LR/DR and in the kitchen that this heart is in, we're leaning towards sheetrocking the wall, adding a mantle, and tiling the area inside the mantle.
There are lots of how-tos on the web if you plan to do this, but essentially you secure strapping to the brick wall, up to wherever you want the hearth facing to be, and sheetrock as usual. Observe code clearances for the firebox-to-combustibles measurement. Add a mantle (salvaged, store-bought, or custom made) and either leave the brick within it, or tile the brick.
Once you have a blank sheetrocked wall, you can even add built-ins if you want. Fastening securely into brick is a PITA (our house is brick, I know!) but do-able. Get a hammer drill and masonry bits and screws.
It'll look just like a normal wall and fireplace. Just make sure you're not wrecking something of valuable character that gives you home personality! That's my big concern with ours. If the off-center shelf and recessed arched niche were not there, I would leave ours as-is and simply add a cool thick salvage wood mantle slab over the fireplace... but the wall is big, dark, and crying out for some art, which can't be placed because of the brick protrusions.
I don't know if this is exactly what you're looking for but I had this pic saved in my inspiration file.
Dee
Fireplace
So you could do that, and also add a neat rough-hewn or varnished slab of wood over the fireplace as a mantle. Like this one, where the brick was skim-coated with cement and the mantle added:
and here are a whole bunch where the brick wall was faced in slate or other stone (any of these could have a slate or wood mantle installed, too):
and of course if you just sheetrock the surrounding brick walls the sky's pretty much the limit and you can do a "normal" hearth in any style you like. I personally like this more modern one!
Here's one
Here is a link that might be useful: fireplace reno
This was a total DIY project for us, including making the mantle. I'm including an idea someone told us long ago and that is to put in a rope light (shown in bottom photo) between the mantle and wall. It is wired into a wall switch but gives a nice glow to the room, especially highlighting a holiday mantle. We cement boarded over the bricks and then applied the tiles, and totally replaced the ones on the floor.
We had a very similar setup, but someone had painted the wall brick but not the hearth. And there was a different brick on the floor, so we had 3 different bricks going on in there. (My children quickly dubbed it the Brick Room.)
We did a lot of looking on google and flickr - do keyword searches and you'll get a lot of good ideas. Stacey really gave you a good summary of the options - plaster over it, tile over it and or add a surround. There are also prefab fireplace surrounds that you can install, do a google search for those. The general rule is that you have to have non-flammable materials for 12 inches around the fireplace...so no drywall or wood.
Since I was using tile on the floor, we decided against tile and had the guys (I am not a DIYer) plaster over the brick, and then we painted it. Then we added a whole walnut paneling thing that I love but is very taste-specific.
Oh - when we opened the wall we realized there were actually two fireplace stacks on that wall for some reason (gotta love old houses), so we decided to use the lefthand one and turn the righthand one into a cabinet for the TV components.
Here's the before:
And the after:
these are great guys, thanks!
