converting html to pdf
mlou_51
13 years ago
Featured Answer
Sort by:Oldest
Comments (14)
mlou_51
13 years agoRelated Discussions
My floor plan is in PDF -- how do I get it to an image?
Comments (3)Are you on a Windows machine (versus a Mac)? If so, probably the easiest way to do it is 1. Open the PDF file with Acrobat Reader (or the PDF viewer of your choice). Zoom in on the plan so that what you want to capture is displayed. 2. Hit "Ctrl + PrtSc" to capture the current screen 3. Go to you favorite image viewer (e.g. Windows Paint) and hit "Ctrl-P" to paste the image 4. Hit "Ctrl-S" to save te image in JPEG format and then upload to your favority photo sharing site (e.g. Photobucket) Hope this helps! Good luck! Jaymie...See MoreSaving PDF to hard drive
Comments (3)I solved my own problem. In the original e-mail I was able to Save to the desktop where I was able to use the converter just fine. Glad I was able to figure out something so simple. Just a senior moment, I guess....See MoreHow to convert TO a PDF. ?
Comments (4)I used ravencajun website and than I tried my scanner. If I scan a picture or a file and scan them as a Document my computer gives me the option to save as a pdf file. I have a HP 3 in 1 printer, scanner, copier. cg...See MoreGood html book
Comments (3)Actually, owbist, I forgot to also ask for CSS book suggestions in the original question. Blame it on the dogs taking an unauthorized trip outside of my property as I was typing... ever said those words "what are my dogs doing in front of the house???" Hee, hee, hee. Those babies..... Regarding your google suggestion for xml, that made me wonder what is the difference between html and xml? I am familiar with the generalized mark up language used in html from my days as a mainframer but I never used it to build html code and webpages, only documentation for the users of certain applications. Now I am being asked to help out a non-profit organization who uses hmtl and css so I need to brush up my knowledge. Have no experience with CSS but got some books on the subject. But the 1st question that popped up was what is the difference between html and xml. When is one preferred over the other?...See MorePooh Bear
13 years agomlou_51
13 years agoravencajun Zone 8b TX
13 years agomlou_51
13 years agoPooh Bear
13 years agofruitjarfla
12 years agomikie_gw
12 years agonocando
12 years agoaputernut
9 years agoowbist
9 years agokudzu9
last year
LIVING ROOMSHow to Convert Your Wood-Burning Fireplace
Learn about inserts and other options for switching your fireplace from wood to gas or electric
Full StoryBATHROOM DESIGNConvert Your Tub Space to a Shower — the Planning Phase
Step 1 in swapping your tub for a sleek new shower: Get all the remodel details down on paper
Full StoryBATHROOM DESIGNConvert Your Tub Space Into a Shower — Waterproofing and Drainage
Step 4 in swapping your tub for a sleek new shower: Pick your waterproofing materials and drain, and don't forget to test
Full StoryINDUSTRIAL STYLEMy Houzz: From Raw Space to Hip Home in a Converted Utah Garage
Creative repurposing with an industrial edge defines the first home of an engaged couple in Salt Lake City
Full StoryBATHROOM DESIGNConvert Your Tub Space to a Shower — the Fixtures-Shopping Phase
Step 2 in swapping your tub for a sleek new shower: Determine your mechanical needs and buy quality fixtures
Full StoryBASEMENTSBasement of the Week: Modern Style Converts an Empty Concrete Box
From raw wasteland to fab living, sleeping and storage space, this snazzy basement now covers all the angles
Full StoryBATHROOM DESIGNConvert Your Tub Space Into a Shower — the Tiling and Grouting Phase
Step 3 in swapping your tub for a sleek new shower: Pick the right tile and test it out, then choose your grout color and type
Full StoryREMODELING GUIDESKnow Your House: The Steps in Finishing a Basement
Learn what it takes to finish a basement before you consider converting it into a playroom, office, guest room or gym
Full StoryHOUZZ TOURSHouzz Tour: From Olden Church to Soaring Modern Marvel
Pray join us on this trip through an incredible home in Melbourne that's a real sanctuary
