This morning, I moved my mouse to bringmy computer out of sleep (not sure that technically it was sleeping - I leave it on at night). I got a blue screen that said Windows has encountered a serious failure and needs to close. If this has happened before, there's a problem (that's the gist of what it said). If this is the first time it's happened, just restart the computer.
Well - this has happened before. Maybe 3 other times - spread several months apart over a year or so. And I've never figured out what the problem was. One time when I had a scare from Winpatrol that I might have a registry attack, Raven sent me to Landzdown forums - I brought this up there while I was at it - but we didn't find any problems and ran a number of tests (I forget which ones). That was several months ago and today it happened again. I did not install anything new before this. My husband did close my firefox browser abruptly (loosing many tabs I had open) and my daughter was on my computer (since I haven't fixed her fan issue yet). Wish I could remember if previous occurences were when she used my computer before. This time she had my permission since hers was shut off til I could open it and check out the fan.
I am not sure what to do. I will report what I can of what occurred.
1 - the blue screen about windows encountering a problem and needing to shut down to prevent damage to the computer. There was something about removing newly installed programs in safe mode if needed.
2 - upon restart, a line that said there was hard drive failure (I have never seen that before). I had choices of F1 or F2 - I chose F1. Don't recall the difference.
Troubleshoot a problem with a device driver, run disk check (I think). I could not figure out a way print this screen.
Upon starting up and windows (XP sp3) opening, it said a serious error occurred - I gave permission to report to microsoft. When I clicked for technical detail, it said the following:
error Sign
BCcode: 7F BCP1: 00000000 BCP2: 00000000 BCP3: 00000000
BCP4: 00000000 (I think that last digit was a zero - my handwriting is so bad it looks a bit like a 6)
OSVer: 5_1_2600 SP:3_0 Product: 768_1
C:\docume~1\Lynn\locals~1\temp\WERd113.dir00\mini121010.01dmp\sysdata.xml
And below is the only thing I could copy and paste that cropped up in Firefox as a tab that said "Restore Session";
You received this message because a device driver installed on your computer caused Windows to stop unexpectedly. This type of error is referred to as a "stop error." A stop error requires you to restart your computer.
Steps to address this problem
Use Windows Update to check for updated drivers
Click to go online to the Windows Update websiteClick to go online to the Windows Update website
Click Custom to check for available updates.
In the left pane, under Select by Type, click Hardware, Optional. Select the updates for a device driver, click Review and install updates, and then click Install Updates.
Note
We recommend that you install all High-Priority updates. These updates improve your computer's security and stability.
Steps to work around this problem
Warning
These steps are designed to address a particular problem but might do so by temporarily disabling or removing some functionality on your computer.
If this problem occurred after you installed a new hardware device on your computer, the problem might be caused by the device driver. Go online to learn how to use the Dell Driver Reset Tool or uninstall the driver.
How do I disable or uninstall a device driver?
- Click Start, and then click Control Panel. If you are using Classic View, click Switch to Category View.
- Click Performance and Maintenance, and then click System.
- Click the Hardware tab, and then click Device Manager.
- Click the plus sign (+) next to the faulting device. You should now see the device listed.
- Right-click the device, and then click Disable or Uninstall.
If this problem occurred after you installed new software, the software might have installed a driver that caused the problem. Try uninstalling the software.
How do I uninstall a program?
Click Start, click Control Panel, and then click Add or Remove Programs.
Click Change or Remove Programs, click the program you want to remove, and then click Change/Remove or Remove.
Note
If the program that you want to uninstall isn't listed, it might not have been created for your version of Windows. To uninstall the program, check the information that came with the program or contact the manufacturer for more information.
If you don't know the specific driver or software, go online to learn more about performing a System Restore.
* For information about your support options, go online to the Support.Dell.Com website."
Other information that might be pertinent:
I keep up to date with Windows Update (although I know I did some computers after this last Tuesday Microsoft update. I am pretty sure I did these high priority updates.
I did the latest Adobe Flash updates in the past week - but probably this weekend.
I have a 500GB hard drive. Dell Inspiron 530 - from Jan. 2008 (still under extended warrantee, I believe). Windows XP SP3, 3 GB RAM, second internal 1.5 GB hard drive, external 670GB Western Digital hard drive with a clone/copy of my hard drive from a few months ago with Acronis. But I still have not felt any sense of mastery or regular use of Acronis. I think there are ways to just back-up what's recent, but when I did it a few months ago, I think it just did everything (which I'd done in May/June already). It started filling my external hard drive so I haven't done it again bc. I don't know how yet to do just the incremental changes that won't fill the drive). I have no idea how I did that copy or how I would use it to restore if necessary. So far the second internal hard drive just has some videos, pictures, and other documents. I am going to copy all My Document files to it now - in case my hard drive fails).
Only other new thing I've done is use Picasa 3 (installed a few weeks ago) to re-organize pictures into appropriate folders this weekend - and got some pics from my husband's camera onto my computer.
I don't know how worrisome this event is (so please let me know if I should be very worried). And then of course any ideas of how to proceed would be helpful.
Of course all this would happen when I was in over my head with struggles my daughter and husband are having. Hard to imagine that I have to find time to deal with this when they need so much from me now.
Thank you.
Lynn.
kudzu9
lynnalexandraOriginal Author
Related Discussions
i am in need of serious help!!! how do you grow giant tomatoes?
Q
I need serious weed help please. I don't know what to do.
Q
Wolf dual fuel DF366 enamel failure What to do?
Q
What should I do in this difficult area? It is a serious eye sore.
Q
zep516
ravencajun Zone 8b TX
windslam
zep516
kudzu9
grandms
jane__ny
jane__ny
kudzu9
