| Your probably reading this because of the subject line!
C'mon .. admit it! 8) Well here goes: It did me absolutely no good to upgrade my system to FIOS.
Well, it's because I haven't been able to connect the modem to the pc by ethernet cable since day one! I am actually running this pc .. using a usb adapter, sitting not three feet away from the actiontec FIOS router! Here's the dumb question: Is the intel 82566dc-2 gigabit network connection that you see in the device manager .. a part of the pc ethernet port connector? (What you plug the cable into) I ask because I can't connect with the ethernet cable and can only use the usb dongle. The intel 82566dc-2 gigabit network connection shows a problem in DM (yellow yield sign). I have disabled the thing.
So now I need to know .. are the two things mentioned above related and if so .. should I just replace the card? Thanks Everyone! |
| 82566dc-2 gigabit network That's called the network adapter, that's associated with the card yes, can you right click on it, choose uninstall, reboot the computer. Didn't the FIOS techs make sure everything was working before they left? |
| Where did you get the gigabit driver from ? You might want to read this page,, and maybe try the generic driver set. Might want to make sure you have a working network cable too if after the generic driver you have non working ethernet. |
Here is a link that might be useful: Intel Generic driver
- Posted by ravencajun (My Page) on Thu, Nov 15, 12 at 0:31
| I would call Verizon and demand that they send someone who can get you set up like they should have done. |
- Posted by justme4now (My Page) on Thu, Nov 15, 12 at 0:54
| Thank You Everyone. It really wasn't the techs fault. I have tried the uninstall/reinstall trick. I have downloaded the 'correct' updated 64bit drivers from intel and guess what .. The driver will not update!? (Device manager can't install it from my folders and intel's autorun wont work either) Tried it both ways. If I can figure out a decent replacement (meaning cheap 8) I have read that even if the pc card is integrated, you can still install a separate stand alone card. (Yes the cable is brand new.) |
- Posted by ravencajun (My Page) on Thu, Nov 15, 12 at 2:14
| Yes. It basically just slides into a slot, may be a couple of screws to tighten. They are not expensive. Lots of you tube instructions to view. |
- Posted by justme4now (My Page) on Thu, Nov 15, 12 at 16:21
| FWIW; think Usb 2.0 is supposed to be 35mb/s actual best speed. Regular network adapters will probably talk faster to your fios, but 35 is fast ! |
